Is 42 degrees Celsius an acceptable temperature for an Athlon XP 1900+ CPU?
Results 1 to 5 of 5
Thread: Is 42 degrees Celsius an acceptable temperature for an Athlon XP 1900+ CPU?
    Registered User red_dog_1515's Avatar
    Feb 2002
    Currently my Athlon XP 1900+ CPU is running at 42 degrees Celsius. Is that ok? What is the highest is can go, still be stable, and not get damaged?
    Also my system temperature is about 41 degrees Celsius. Is that ok? What is considered ok for system temperature?
    Great White Shark d_k's Avatar
    Oct 2001
    Re: Is 42 degrees Celsius an acceptable temperature for an Athlon XP 1900+ CPU?
    Is that temperature under idle or load?? THose are some pretty high temps for a HSF like that Did you use arctic silver thermal grease , do you have any case fans?? The reason your CPU temps are so high is because your CPU temp will never be lower than your Case/system temp If you had some case fans your CPu temp would be much lower
    BTW as long as your temp doesnt go over 60 C , youll be fine .
    Pennsylvania
    I think thats pretty good. Im running at 40c.
    Lian Li PC60
    OCZ Modstream 520
    Asus M3A78
    Athlon 64 X2 5000+
    OCZ Platinum 2x 1gb PC8500
    Western Digital 36G Raptor
    Western Digital 200G SATA
    Western Digital 640G SATA
    XFX Geforce 7900GT
    Acer F-22
    Windows Vista Ultimate SP1
    A+ Certified
    Network+ Certified
    Texarkana, TX
    Talking
    42 is a good temperature. Just for grins leave the side of your case off and see if it runs much cooler--if it does you might need better case ventilation. Also, do run some processor intense applications and check the temperature then to see what a difference the load makes.
    Mr Zurkon is here to kill PointlesS's Avatar
    Polaris Galaxy
    42 is fine...
    Lian Li PC-K7B | Intel i5 750 | 4GB A-Data 1600 | Gigabyte GA-P55-UD3R | XFX Radeon 5850 | 2-640GB WD Caviar Blue | X-fi Xtrememusic | Klipsch Promedia 5.1 Ultra | Dell U2311H | Antec Basiq Plus 550W | NEC 3550A | Win7 Ultimate x64
    and a whole lot of lovin..
