Sony CPD-420s or Viewsonic p95f
Ok here it is I need to know which monitor is better I can't decide I have been looking it over and over again. So give me your opionons on these two monitors and please give a final suggestion either the Sony or the Viewsonic.
Link for the Sony CPD-420s:
http://www.sonystyle.com/vaio/displays/cpd_g420s.shtml
Link for the Viewsonic p95f:
http://www.viewsonic.com/products/crt_p95f.htm
If you have a better monitor suggestion in the same price range nothing higher than $400 please post a link to it.
Make sure you please suggest either the Viewsonic or the Sony.
Don't run with scissors!!
I suggest a NEC FE950+. Those other two are overpriced, and aren't as good.
Come on guys, give some feedback, I can't decide!!
I like the Viewsonic but I know Sony is a reliable name brand.
They're both great monitors. Just get the cheaper of the two, you won't be dissapointed.
Athlon 64 3700+
2GB Micron DDR400
Shuttle ST20G5 SFF
ATI X800XL 256mb
Seagate 160GB
Generic 8x4x8x DVD+-RW
Dell 17" Trinitron (just bought a 2005fpw!!)
And my soon to be 1.5TB server
Yeah but the Viewsonic is perfectly flat and the Sony is virtually flat will I be able to tell a difference?
No-it's perfectly flat, I'm about the only one here who has one
Get the cheaper of the two-they're both equal and that will help the grand scheme of pricing with competition and whatnot
Oh so then if they are both perfectly flat I will go with the Sony then. THANK YOU! The first person who could answer that freaking question even the people at EMS Computing couldn't tell me wheather it was flat or not!
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
