Results 1 to 8 of 8
    Feb 2002
    Optical Mouse and Bass do not mix
    Has anyone else has this problem before? When I have my speakers pumped up, my optical mouse is very bouncy. The subwoofer is vibrating my desk which is causing the jumping, I believe. Can this be fix with an optical mouse pad or should I just keep the bass turned down a notch? What's the point of having a game with a great soundtrack if you can't turn it up? It seems that the optical mouse / good sound system mix doesn't work.
    It's a logitech optical mouse in case anyone was wondering.
    SF
    your reflection patssle's Avatar
    inside your mind
    my optical is on a mousepad and it dosnt bounce around, even with bass on full and volume up.
    Pennsylvania
    Yea same here..
    Lian Li PC60
    OCZ Modstream 520
    Asus M3A78
    Athlon 64 X2 5000+
    OCZ Platinum 2x 1gb PC8500
    Western Digital 36G Raptor
    Western Digital 200G SATA
    Western Digital 640G SATA
    XFX Geforce 7900GT
    Acer F-22
    Windows Vista Ultimate SP1
    A+ Certified
    Network+ Certified
    Washington DC
    Did IQ's suddenly drop while I was away...
    If turning the volume up loud enough to vibrate your entire desk and causes mouse problems, then YES turn the volume down
    Main rig:
    P4 2.8C / Asus P4P800
    2x512MB Corsair 3500C2
    Leadtek GF4 4200 / Samsung 181T
    Seagate BV 120GB / M-Audio 2496
    Zalman 7000AlCu / Antec 420W PSU
    Tiger Shark omesie's Avatar
    Feb 2002
    Melbourne, Australia
    you do have the Subby on the floor right??? just a question...
    some people do put it on their desks...
    I don't have a signature...
    I'm not very creative...
    Tiger Shark archshrk's Avatar
    Jan 2002
    Re: Optical Mouse and Bass do not mix
    Have you tried adjusting the mouse sensitivity down?
    Feb 2002
    Hmmm, Adjust the mouse sensitivity down, I didn't even think of that!!! I will try that once I crank it up again. The sub woofer is on the floor but tends to shake everything anyway. The desk is wood and metal and seems to vibrate with the floor. I live in an apartment building so I guess I should be cooling it anyway. But I am going to try and lower the sensitively cause once the weekend rolls around the Klipsch's 5.1's get to flex there stuff.
    Thanks for the help,
    SF
    Hammerhead Shark janko10's Avatar
    Apr 2001
    Me too.
