Results 1 to 6 of 6
    The Gothic Shark GeForce's Avatar
    HELL
    Unhappy MOHAA Preformance problem.
    Hello Sharky!
    2 days ago I re-installed MOH:AA. It's the first time that I installed it with my Ti-4600. I finally got a new 2nd CD.
    Anyways, the game worked "OK" on my GeForce 2 MX-400. I played on semi high settings... and on 800X600X32. Now. I put the game on the same semi-high settings that I used for me MX-400. Only thing I changed what the resolution. I put it to 1024X786X32. The game runs like CRAP. I get 10 - 15 fps in outside enviornments if I'm lucky. The games runs fine when I'm indoors.
    What's up? I have the 28.80. I tried the 28.90 but I got the same preformance. NO AA. NO V-Sync.
    Please help me. All my other games run GREAT on MAX settings and AA X 3 or even 4 sometimes.
    This is pissing me off. Will the new patch fix it? I didn't install any patches yet.
    Thanks!
    HELL
    Please help me...
    Hammerhead Shark sublim21's Avatar
    Oct 2001
    Oakdale Ny U.S.A.
    first off, installing patches are always a good idea, and if that still doesn't work, then it might be because of previous drivers still hanging around, causing problems and such. I'd say reformat, or at the very least uninstall the current drivers you have, get nvidia driver remover Here to make sure you get rid of everylast part of your drivers, and then get the newest drivers Here. Good Luck
    Specs - mobo: Asus m2n-sli deluxe with an Athlon X2 4200. Videocard: 7900gt Ram: 2 gigs
    Sleeps with the Fishes
    Vancouver, WA, USA
    Hey GeForce this dont really answer your question nor have much relavence but what was wrong with you CD 2? I get some stupid error around 57% and want to know if its the same error as you.
    HELL
    SAME!!
    I got it at 63% everytime. I just burnt the 2nd CD from a friend..
    sublim21
    Thanks for your help man.
    Tiger Shark mr freeze's Avatar
    Md
    That game ran fine on my 1.1 tbird and gf3 ti200 setup at 1024x768 with all options maxxed except no AA.The only slowdown I had was with the gas mask on.I finished it so quick the patch wasnt even out yet.
    Intel Dual Core e6400@3200mhz
    Gigabyte 965p Ds3
    XFX 8800Gt Alpha Dog 512mb
    2GB Corsair 800 DDR2
    Seagate 120Gb HD
    X-Fi Extreme Music
    Pioneer 16x DVD
    Acer 24" Lcd
    Logitech Z680s
    WIN XP Home
    Antec 550watt PS
    Ultra black mid tower case,1 120mm,1 80mm case fan
    Steam:mr freeze
