Results 1 to 7 of 7
    Aug 2002
    Question Old thermal compound removal??
    Hi,guys. I am about to change my old stock heatsink with aluminum one for better cooling. I noticed that there is residue of the old thermal compound on the CPU core. How can I remove it without damaging the core?? Thank you.
    Catfish OneShotUno's Avatar
    Jan 2002
    Northeast Pennsylvania, USA
    Last time I needed to clean my heatsink and core, I was told to use isopropyl (rubbing) alcohol. It cleaned the artic silver right off and I could see the clean, untarnish copper where my core had sat for several months.
    Athlon 64 3500+ | MSI K8N Neo2 Platinum | 1024mb Corsair PC3200 TwinX Low Latency | Leadtek Geforce 6800 Ultra | Sound Blaster Audigy 2 | Logitech Z560 4.1 speakers + 1 Klipsch SWS | Matching Black Lite-On DVD-ROM and DVD-RW | Seagate 160gb Barracuda V | Logitech MX500 Optical Mouse | Black Coolermaster Wave | Vantec Stealth 520 watt | Windows XP Pro
    Aug 2002
    Cool
    Thanks for your reply. Just one quick question, where can I get isopropyl alcohol?
    Sep 2001
    Red face eee
    Try nail polish remove if you dont have isopropyl alchohol.
    Tiger Shark BigBlue66's Avatar
    Feb 2002
    Madison WI USA
    You can buy the alcohol at any friendly neighborhood pharmacy. As OneShot said, it's commonly referred to as Rubbing Alcohol. Try to get the 91% or more.
    Captain Blue of the Cooler's Guild.
    Vantec Nexus 201 Controller Idiot Boy. You cannot call me numnuts.
    Main Home Rig: Asus A7N8X Deluxe 1.06, XP 2600+/333, 1,024mb HyperX PC2700, lapped AX-7 w/53cfm Mechatronics, Seagate Barracuda V SATA 7200rpm, Audigy2 Platinum, BFG Asylum GeForceFX 5700 Ultra 450/900 (Oh Yeah!!), 2.1 Microworks, 4.1 Z-540s, Modded Compucase Series 6A, Antec True430, Vantec Nexus 201, Koutech 6n1 Card Reader, blue lights, copper coated round cables, stealthed wiring etc.
    Hammerhead Shark morphid's Avatar
    Somewhere south of Wambangalang
    i use alcohol too, but once, no matter how hard i tried, i couldn't get get the old thermal compound off (it was the old pink hard stuff that comes with bad HSF's. I used stove cleaning compound. it's the white gooey stuff you buy to get the burnt food residue off hard stove tops. it worked like a charm. the old compound slid off like a sled on a slope <- i made that one up myself. im proud .
    Great White Shark Thermo's Avatar
    SE PA
    Go to Walmart or Pep Boys and get a can of Break Clean, spray a little on a rag and the AS will just wipe away.
    "All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
    January 21, 2013 The End of an ERROR
