Results 1 to 14 of 14
    Sep 2001
    At what resolution does everyone play there games at, and do you turn on FSAA and AF?
    At what resolution does everyone play there games at, and do you turn on FSAA and AF (Say what settings you set them on) ? Wondering everyone's opinion on resolutions, FSAA, and AF?
    Thanks.
    Great White Shark Farmer_BOB's Avatar
    Apr 2002
    16x AF (that's max in ATI land), and 2xAA.
    Sep 2001
    Farmer_BOB what resolution ? And do you play all your games with 16 AF and 2x FSAA on ?
    Apr 2002
    I play all games @ 1024*768 32-bit. With ATI cards, maxing out the AF all the way doesn't give it a big performance hit. Since I'm using an 800mhz p3, I don't always enable AA. But, since I play at high resolutions, it's not a big difference.
    Man With Nothing To Lose jagojago12's Avatar
    Seattle, WA
    I play every game at 1024x768@32-bit color. The only game that's fast enough to be played at 4X FSAA and 8X AF is Half-Life and the game has textures problems when enabled . I can turn on Quincunx to fix the texture problem but everything becomes blurry .
    "If everything you try works, then you are not trying hard enough." - Gordon E. Moore
    Desktop:
    AMD Athlon XP 2100+@2.31GHz (11.0x210) | EPoX EP-8RDA+ | 512MB Crucial PC3200 | VisionTek GeForce4 Ti4600 | nVidia SoundStorm 5.1 | 160GB 7200RPM Western Digital | 48x/12x/48x Lite-On CD-RW | Lite-On 16x DVD-RW | 19" NEC AccuSync 90
    Laptop:
    Intel Pentium-M 1.4GHz ULV | 512MB Nanya PC2700 | ATi Mobility Radeon 9200 | 60GB 4200RPM Toshiba | 8x/16x/10x/24x Matshita DVD/CDRW | 12.1" Sony XGA TFT
    SharkyExtreme 3DMark Team
    Canada
    Generally, I run 1152 32bit max AF.
    Only game i use FSAA in is NFS Porsche.
    Systems
    AMD XP 2100@2300mhz (11.5X200)\Radeon X800 Pro\ Asus A7N8X\1GB SAMSUNG PC400\WD 80GB\Maaxtor\160 GBSound Blaster Live\21" NEC MultiSync FE1250 \ATI TV-Wonder ALTEC Landsing ATP-3
    PC-2
    AMDXP 2400 \Radeon 8500\ ECS K7S6A\512 DDR333\WD 40GB
    Great White Shark Terry's Avatar
    Seattle, WA
    old games are 1024x
    new are 800x600 or below
    no fsaa or anything.
    Member of TSGG & ITG
    HEATWARE
    Follow me down the rabbit hole:
    Spoiler
    Apr 2002
    I also have NFS porshe, and I know it's a very processor intensive game. So my question is, does it run perfect with your current rig?
    Canada
    NFS appears smoove as silk to my eyes, but when I run fraps I see that I am getting 60-30fps. These frame rates would be nasty in a FPS, but in a racing game they aren't a problem.
    Systems
    PC-2
    BANANARAMA FOFANA tu2thepoo's Avatar
    BLARRRG.
    1152x864 32-bit when the game allows it.
    usually just stick with trilinear filtering, unless a game looks significantly better with Aniso filtering (like Morrowind), in which case i use level 4 (32-tap).
    in all honesty, though, Omega's NVIDIA drivers often deliver nearly the same image quality as 32-tap anisotropic filtering, without nearly as much performance hit. however, there's some games where the increased LOD settings make the game look like **** (like the Phantasy Star Online demo). i got tired of dealing with it (and i hate Nview), so i just went back to the 23.11 detonators.
    (celeron @1330mhz, GF3-ti200 @226/526)
    Tiger Shark Vlad_M's Avatar
    Cape Town, South Africa
    1600*1200 no fsaa aniso 8x
    I wish I knew...
    Mako Shark JustW's Avatar
    Oct 2001
    Louisville, KY
    I currently play at 1024x768@32bit with Quincunix AA and 8x AF. When I get a new monitor though I'll probably play at 1280x960, with the same settings
    Evil Monkey Shark thebove's Avatar
    West Bloomfield, MI
    i run 1024x768 on everything, no AF or AA, unless it's a racing game, then i crank the AA to 4x
    - 2xRaptor 150GB RAID-0
    Dave? Dave?! Dave's not here...
    Reef Shark Talonator's Avatar
    Up **** Creek
    The TalonatorZ!@!
