I have an old ATI 64mb-DDR-VIVO card and I went to plug in my new mobo Asus P4B533-e and the machine won't boot? ( I don't hear the short beep when pc boots-up) the videocard is Agp 2x-Agp4x universal and I do not know the voltage on this card. The Mobo says it takes a 1.5v video card...do i need to get a new video card? Any recommendations would be helpful... and please suggest any new reasonable video cards... Ati Bloe's
Thanx in Advance
DhootiMaDhamal
If the Accounting numbers don't look rite, just add a few more zer0's no one will ever know.
Lian-Li pc-71 with custom side window
MSI GF4 4600 VTD 128mb
CompUSA 600 wt PSU (Hey it works great for me)
P4 2.53 ghz cpu, not o/c yet
Corsair XMS PC3200C2 2x512mb
Asus P4B533-E
Swiftec MCX 4000 w/YMD 74 mm fan
Silver Braided Glow round cables
Plextor 12/10/32 cdr-rw
Creative Labs DVD 12X
1-80gb Western Digital 8mb Buffer
1-120bg Western Digital 2mb buffer
HP 200I DVD +R+RW
Klipsch promedia 4.1
22 inch Sun/Sony Trinitron Monitor
I found the mobo @ googlegear, I bought it for $168.... The mobo will not recoginize the videocard. according to the user manual, it says it's a proctection feature so you do not burn out the mobo. the computer will not start till it finds a useable video card. I guess i'll have to order the MSI geForce 4600 i saw for $250.
Danr, Ati's Bloes
DhootiMaDhamal:rolleyes:
Asus P4B533-E
HP 200I DVD +R+RW
you are lucky its an Asus and it has that protection - if you had plugged it into another board with the same chipset you would have burnt the board out
yes, you need a newer video card
Northwood 2260 @ 2822 (166 Bus)
Asus GeForce 4 4600 Ti
Asus P4B533-V with iPanel
512mb Crucial PC2700 @ 166 (333MHz DDR)
12109 3DMarks
Lucky? no, I had to RMA the mobo, cpu, and my memory back to googlegear, all my test failed, they will run the tests and send me my stuff back.. so I'm out of luck for two weeks....
DhootiMaDhamal
:rolleyes:
Asus P4B533-E
HP 200I DVD +R+RW
Asus P4B533-E
HP 200I DVD +R+RW
