cd rom driver wont load please help
Results 1 to 3 of 3
Thread: cd rom driver wont load please help
    Goldfish Rednose's Avatar
    Apr 2002
    Liverpool
    Lo guys,
    The strangest thing has just happened, ive recently upgraded to win 2000 pro, everything running fine for over a week now, im still installing some software, but today i installed my hewlett packard cd/rw software. Now my HP 9100 cd/rw drive has been working fine, but when i installed the writing software windows cant find my cdrom, it says it isint working properly because it couldnt load the driver(code 31). ive tried reloading the drivers, unpluging the drive and repluging but nothing, windows just wont have it. what pisses me off is that it was ok untill i installed the official software. The drive works fine in DOS so its not broken, but the cherry on the cake was when the guy at hewlett packard wanted 23.00 to give me some technical help because its more than 12 months old.
    If anyone has any ideas i would like to hear them.
    THANKS FO ANY INFO..
    Hammerhead Shark Totally_Bug_OuT's Avatar
    Lodi, NJ, United States
    You really don't need the HP software.
    Try using Ahead Nero, and see if the software detects your drive.
    AMD X2 3800+ @ 2.65Ghz
    DFI LanParty SLI-DR
    BFG 8800GTS 640MB
    2x WD Raptors RAID 1
    2 x 1GB Crucuial Ballastix
    OCZ 420 PowerStream
    Dell 2005FPW
    Hammerhead Shark LordOPain's Avatar
    illinois
