Results 1 to 2 of 2
    Registered User ptamim's Avatar
    Jan 2002
    Philly, PA
    Painting my aluminum case
    Hey guys,
    I said what the hell... I'm tired of my plane Jane computer... so I thought to myself... why not spruce it up a bit. So first step is to paint the case. It's around half way done. It's a Lan Li case... I primed the case with some rustoleum primer... now I'm painting it a nice red color... afterwards I'll put on a clear coat finish to give it some shine. I'll send pics once I've got it done. Wish me luck !
    After all, I had to something productive with my time now that I'm out of the hospital !
    Dr. T
    Reef Shark G33K's Avatar
    Apr 2002
    Tampa, FL
    Sounds like it will look sharp! Keep us updated! And good luck.
    ~ GO BUCS ~
    My rig...
    OS - Win2k Pro
    Case - Kingwin KT-436S
    PSU - Enermax 431W EG465P-VE(FCA)
    CPU - AMD XP 1900+
    HSF - SLK-800 w/ 80mm TT Smart Fan II
    RAM - 1GB Crucial Micron PC2100 DDR
    MoBo - Gigabyte GA-7DXR+
    Video - PNY GeForce4 Ti4400 128MB DDR
    HDD - Maxtor 40GB 7200 RPM, Maxtor 30GB 7200RPM
    Optical - LiteOn 40x CDRW
    Optical - LiteOn DVD
    ________________________________________
