I just loaded XP Pro on my laptop system. The thing is, is it is a an old 166MMX PI, 72MB RAM (Type unknown), 4.3GB HDD, NeoMagic 1.5MB Graphics. Dell Latitude LM. XP Pro works great on it, no slower than it was before with 98SE, and the screen looks better. So far so good. I mean Hell, all I use it for is writing and bit of surfing and chatting. I just wanted to see if it would work and it DID!!!
Thing One: Core2Duo E7200 @ 3.6GHz//2x2GB OCZ DDR2 800//Asus P5Q Pro//ATi HD 4850 PCI-E//ATI TV-Wonder HD650//500GB SATA Caviar Black HDD//12x LiteOn DVD-RW//22" Acer LCD Widescreen
Odd when I tried it on my 450Mhz PIII 128MB RAM it was slower then a dog. Hmm I have yet to try it on my T-Bird 1Ghz 256MB DDR2100. No doubt it should be smoother lol but for right now I am pretty comfortable with Windows 2000 + Service Pack 2 = Very Stable.
Originally posted by Indus The minimum requirement AFAIK is only 64mb of ram because here..
That's a non mmx and 64mb EDO ram comp.
Is that screenshot of a PC from Louisville, KY, Sluggerfield? I went there this past May for that Intel ISEF stuff. Very fun. A lot of commotion near the galleria, Hyatt and Galt holtels .
"If everything you try works, then you are not trying hard enough." - Gordon E. Moore
Desktop:
AMD Athlon XP 2100+@2.31GHz (11.0x210) | EPoX EP-8RDA+ | 512MB Crucial PC3200 | VisionTek GeForce4 Ti4600 | nVidia SoundStorm 5.1 | 160GB 7200RPM Western Digital | 48x/12x/48x Lite-On CD-RW | Lite-On 16x DVD-RW | 19" NEC AccuSync 90
Having the "pretty" themes enabled on XP do use quite a bit of RAM. Also, having all of the fading options, smooth sliding, etc (the advanced area when you right click my computer, etc etc).
If you have the RAM, might as well make it look pretty, right?
If you don't have the RAM and want to run XP, that's just something you're missing out on. :/
Until I get my CoolIT chiller, DDR3, and video cards for my 790 3 way SLI mobo...
• Q6600 @ 3.4GHz
• Skythe Infinity Heatsink w/ 120mm
• Asus P5E
• nVidia 8800GTS 512MB
• Samsung 245BW and Samsung 19" Widescreens
• 8GB (4x2GB) Corsair Dominator DDR2
• 3x 150GB Raptor RAID0 / 2x 1TB WD Black / 1x 750GB WD
• X-Fi Gamer
• Windows 7 Ultimate
• Rosewill 1050 Watt PSU
• Coolermaster ATCS 840 Case
• Sennheiser HMD-280 Pro (Headset)
