    Hammerhead Shark Booshanky's Avatar
    Redondo Beach CA
    Post I have a tad bit of a problem......
    Whenever i try and run defrag, it gets about 60% of the way through and then it says that there are errors that need to be repaired and to run scandisk. so i run scandisk, run defrag and it happens again. i have no bad sectors etc, but every time it says that there were errors and that scandisk fixed them.
    i have no programs/screensavers running when i do this.
    one thing is that sometimes my hard drive makes some really wierd noises when it is doing the defrag. it will make the usual hard drive working noise, but then it will make this noise that i can only relate to being at the dentist, and getting a layer of enamel scraped off with on of those scraping tools. i really doesnt sound good. i just got the drive a couple of months ago, and it is an ibm, so i'm not sure what the huge problem is.
    i think i'm gonna try running a scandisk from dos and then defraging from dos. you can do that on a microsoft winme startup disk right?
    PC #1
    AMD Athlon T-Bird 1.1Ghz
    Abit kt7A-RAID mobo
    256 MB crucial 133 mhz cl2 ram in one dimm
    nVidia Geforce 2 GTS 32mb
    sb live!
    IBM Deskstar 60 GB ata100 HD
    Creative CDRW Blaster
    3com NIC
    PC #2
    AMD Duron 600 Mhz Oc'd to 825 Mhz
    Abit KT7 Mobo
    64 Mb Crucial Ram
    Voodoo 3 3000
    Linksys NIC
    Sound Blaster Pro
    Western Digital 15 GB ata66 hdd
    8x CD-Rom
    Reef Shark Gackt2k's Avatar
    Mar 2001
    Surrey, BC, Canada
    u can go to IBM's website and download a drive-fitness program, i had that defrag problem b4, then i run the fitness program and it tells e that i got bad sectors...so...just a thought..good luck
    AMD T-Bird 900MHZ @ 990MHZ
    512mb cas2 SDRAM
    Geforce 2 GTS 32mb pure
    MSI K7T Pro2A
    IBM 30GB ATA100 7200rpm
    Toshiba 16x DVD
    Aopen 12x cd-rw JustLink
    SB Live!
    Samsung 955DF 19"
    Win98se / Windows 2k pro - Service Pack 2
    512mb cas2 SDRAM
    MSI K7T Pro2A
    Toshiba 16x DVD
    SB Live!
    Samsung 955DF 19"
    Logitech Z560
    Win ME / Windows XP Pro
    Ex-*** kid A's Avatar
    Norway
    Does sound like you have bad sectors to me...
    Now listening to:
    Kaizers Orchestra - Ompa Til Du Dør
    Now listening to various rock and metal
    143rd member to join Sharkyforums.
    Great White Shark Thermo's Avatar
    SE PA
    If it sounds sick, it is sick! Send it back and get another one. Every drive I ever heard a strange noise come from, was ready to die.
    Main system <A HREF="http://communities.msn.com/ThermosPlace/shoebox.msnw?Page=Last
    Dual" TARGET=_blank>http://communities.msn.com/ThermosPlace/shoebox.msnw?Page=Last
    Dual</A> 1.7 Xeons
    860 chip set
    512Mb PC800ECC
    nVidia Quadro Pro 64Mb
    Dual 20gig HD's
    Sound Blaster 512V
    12x/8x/32x CD
    W2000sp2
    2nd system
    <A HREF="http://communities.msn.com/ThermosPlace/933.msnw?Page=Last" TARGET=_blank> http://communities.msn.com/ThermosPlace/933.msnw?Page=Last[/url]
    PIII-933/133
    Intel vc820i
    256Mb's PC800ECC
    8gig HD
    VooDoo3 2000
    12x8x32 CDR
    W98SE
    "All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
    January 21, 2013 The End of an ERROR
