Watercooling info - Page 2
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 99
Thread: Watercooling info
  1. #16
    Apr 2002
    Canada
    Originally posted by Pyro
    RADIATOR - Cooler Core Combo from Dtekcustoms with an extra D-Tek Core Fan Shroud Kit. Personally I'd go with the heatercore over BIX. I bet you would notice a 2-4 C drop over the BIX. But then again, the BIX is purdy, small, and compact, so both have their respective advantages/disadvantages.
    Why an additional shroud? where would I put it on the Cooler corew combo? seeing that it looks like it would only support one?
    Desktop: AMD Athlon X2 4400 | DFI Lanparty nF4 SLI-DR | 2GB OCZ PC4000 EB Platinum Edition | eVGA 7800GTX | Gateway FPD2185W | 2x Maxtor 250GB 16MB SATA RAID 0 | Sound Blaster Audigy 2 ZS Gamer | Hiper Type-R 580W
    Coming Soon: Intel Core 2 Duo E6600 | ASUS Striker Extreme Nforce 680I | 2GB Corsair XMS2 8500C5D | eVGA 8800GTX | Sound Blaster X-FI FATAL1TY FPS | OCZ GameXStream 700W | Windos Vista: Home Premium
  2. #17
    Apr 2002
    Canada
  3. #18
    GSD on patrol kenrippy's Avatar
    Orange Co. CA
    Originally posted by speed freak
    If I did something like his, is there anything that I could improve? or is the VGA and CPU cooler he has top of the line? (remember, not really a price issue, but rather quality and performance issue) I'd rather pay more to get more outta something for just a few degrees immprovement, as I want to push my upcoming system to kingdom kong (with out dry ice ) Just click on MY SYSTEM link in my sig, and look at the bottom one, that is what I'm planning on using this setup on.
    the main diff between my setup and most others, is the lines are 3/8" OD and the blocks are a low flow design which are designed for smaller diameter tubing. I personally don't like 1/2" ID tubing because it's so damn big. immagine cooling your CPU, NB & GPU with such large tubing. IMO it makes the inside of your pc look like a home-made washing machine or something (can't come up w/ good analogy ) - mcgyver-ish. if I were just going to cool the CPU then I'd consider using the 1/2" ID tubing and go with a high flow block like the maze3. the actual temp difference between what I have and the larger tubing designed systems is insignificant. I wish someone would do a review on the Innovatek Rev.3 block and some other big name blocks.
    the heatercore vs. BIX debate is possibly won by the heatercore sold by dtek but I can't confirm it since I've never used one. the dual shroud theory is for a fan on each side (push/pull) method and would give better air flow, not sure if it would make a temp diff tho.
    edit: this is what I wanted to avoid
    Q6600 "G0" @ 3.6ghz (400x9) - tuniq tower - IP35 Pro - 4x1gb ballistix ddr800 - Thermaltake W0128RU 650w - 2x74gb raptors raid-0 (OS drive)
    heat ebay
  4. #19
    Apr 2002
    Canada
    lol.
    I honestly don't mind the thick tubing, ans my case would be closed and would NOT have a window
    So, overall, what do you think of the components I'm looking at so far?
  5. #20
    Rolla, Missouri
    I agree with kenrippy about the Maze 3. Main reason being is that you could purchase the Maze with per-assembled 1/2 fittings.
    BTY, that pic of the "1/2" watercooling setup is beautiful.
    It supports 2. Check out nikhsub1's picture of his Pro Core in this thread. The shroud link you had provided kinda shows how the shroud is connected. Also the Pro Core is the same as the silver and unpainted cooler core radiator at dtekcustoms.
    Two is not necessarily needed, but your said it "I'd rather pay more to get more outta something for just a few degrees immprovement."
    You probably already know this, but just in case you didn't...OD means - Outer dimension, ID means - Inner Dimension. So the tubing would need 1/2ID while the adaptors/fittings would have 1/2OD to fit.
    I like the DD 9700 PRO waterblock you had choose.
    Are you still interested in the NB waterblock? If so, I'll have a good recommendation by tonight. Currently I'm reviewing users experiences with the different NB blocks. I still don't believe the NB block is necessary, a good active cooling HS would work fine. But the shroud isn't necessary either so...
    Sharky Extreme 3DMark Team
    3DMark01 = 9700 PRO 18330
    Heatware feedback
    Ebay feedback
    EOC Feedback
    Opteron 144 | AsrockDual-SATA2 | Corsair (2x512mb) PC-3200 Value | Gigabyte X800XT PE | Seagate Barracude 80 GB SATA w/NCQ
    Barton 2500+ | Abit NF7-S 2.0 | Corsair 256mb PC-2700 C2| Jetway 9800 Pro | Maxtor 40gb ATA133
  6. #21
    Rolla, Missouri
    lol.
    So far, so good. Except swap the MCW462-U for the Maze 3.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  7. #22
    Orange Co. CA
    http://www.hwtec.de/Seite.htm here's a good page to see what's out there on the w/c market.
    heat ebay
  8. #23
    Rolla, Missouri
    Excellent link kenrippy.
    For the NB, I like the Danger Den Z-Chip chipset waterblock. It would match the Maze 3 also.
    NOTE:
    "Mounts on motherboards with Center to Center Hole distances ranging form 2.10" - 2.43".
    There's a 250% chance your motherboard falls in this range, though with things like these I always(don't know why) check just to make sure.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  9. #24
    Apr 2002
    Canada
    Ok, so the two extra fans will improve the cooling, so I'll stick with two
    Also, that maze 3 sounds like it is highly acclaimed, so that is on my list. As for OD, and ID, how does that work exactly? (sorry, I am TOTALY new to this water cooled setup thing.)
  10. #25
    Apr 2002
    Canada
    Thanks kenrippy, gives a great perspective of what they should look like, if I gotta pick em out
  11. #26
    Rolla, Missouri
    Speedfreak, no problem. I had asked the exact same question at one time.
    This is a cut and paste from Cathar's Watercooling FAQ.
    "The tubing carries the water from component to component. Tubing can come in a variety of materials and sizes. It is of course best to choose the size of the tubing to match your components fittings.
    When considering the size of the tubing and matching it to your components, it's important to understand some of the terminology of fitting and tubing sizes. There are two measurements, being the "Inner Diameter" (or ID) and the "Outer Diameter" (or OD). The ID of a piece of tubing is pretty much all that you should be concerned with. The OD of tubing is near meaningless for our needs since it just defines how thick the walls of the tubing is when you know what the ID is.
    For fittings, it's important to not confuse ID and OD. You want the "Outer Diameter" of your fittings/barbs to match the "Inner Diameter" of your tubing. It's usually okay if the tubing's ID is up to 1.5mm (or 1/16") too small for the OD of a fitting, as most tubing can typically be stretched at least that much to fit. If you cannot match up a hose with a fitting size (because you may have fittings of differing OD sizes), then you will need to use a hose sizing adapter."
    Heatware feedback
    Ebay feedback
    EOC Feedback
  12. #27
    Apr 2002
    Canada
    I must be tired, I am sorry, I'll look into this tomorrow, as I am starting to feel like a fool, because I just can't seem to grasp it
    lol, I'll be back later on for a new lesson here, as I can barely type. Thanks all, (well, you two guys ) If you want, I am available here at MSN (I just said here at MSN ) u_r_puree@hotmail.com or, well, actually, my AIM, MSN, ICQ, and pretty much everything is in my profile, and my email that I actually check (hehe) is n.veryha@telus.net
    Well, better sign off before I end up leaning on my keyboard thingy (to tired to think of what it's called lmao) and breaking something.
    Sorry if I made you read the jibber jabber at the end, honest.
    Thanks again, and I'm gone as.................ZZZZZZZZZZZ, oh, where was I, oh yeah, of now
  13. #28
    Rolla, Missouri
    Its not a problem. It is quite simple. After it clicks in your head, you'll want to smack yourself.
    If only I had photoshop, it would be so much simplier. Anyways, go HERE and scroll down to the "2.5.3 Garden hosing" section. Notice the somewhat clear colored hose with a blue/gold line on it.
    The ID is the diameter of the "tunnel", the tunnel being where the water flows through. The OD/outer diameter is the whole diameter of the hose.
    Since the ID of the tubing would equals 1/2. The fittings/adaptors OD should equal 1/2. This makes a tight fit when both are connected together.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  14. #29
    Mako Shark mellojoe's Avatar
    Arkansas
    Inner Diameter - Outer Diameter: Let's try to clear this up some more.
    If you take the first finger and thumb of your left hand and wrap them around the thumb of your right hand you get a connection. The left hand fingers make a tube and your thumb makes a fitting. The thickness of your thumb determines how large of an opening you need to make with your fingers. Right?
    It doesn't matter how thick your fingers are making the tube, since all that you are concerned about is that they wrap around your thumb.
    So, the INNER DIAMETER of the tube made with your fingers measures the hole size. The OUTER DIAMETER of your thumb also measure the hole size. Those two numbers need to match.
    However, it really doesn't matter what the outer diameter of your fingers (tube) is. Nothing is going to be wrapped around them.
    The pieces that need to match up are the INSIDE of the tube with the OUTSIDE of the fitting. Its like the male and female half of pipe connections. One peice has to be a bit smaller to fit inside the other. You have to match up the INSIDE of one piece with the OUTSIDE of the other piece.
    I hope that helps some.
    mellojoe
    Knight of the OC Crusades
    --in the Lian Li A16--
    DFI LanParty DK P35 T2RS
    Intel E7200 (2.53) @ 4.0 ghz
    G.Skill 4GB DDR2-1000 5-5-5-15
    Corsair 750W
    evga 9800GTX+
    Lite-ON 20X DVD±RW DL
    --watercooling--
    D-Tek Fuzion v2
    Swiftech MCP655
    2x120mm BIX GTX
    Swiftech MicroRes
    __________
    ________
    ______
    ____
    __
  15. #30
    Apr 2002
    Canada
    ohhhhh, ok, instead of smacking myself, you get to see a much better treat, me smashing my head against a brick wall
    Thanks
