Watercooling info - Page 3
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 99
Thread: Watercooling info
  1. #31
    Rolla, Missouri
    Any other questions? We'll help out as much as we can.
    Sharky Extreme 3DMark Team
    3DMark01 = 9700 PRO 18330
    Heatware feedback
    Ebay feedback
    EOC Feedback
    Opteron 144 | AsrockDual-SATA2 | Corsair (2x512mb) PC-3200 Value | Gigabyte X800XT PE | Seagate Barracude 80 GB SATA w/NCQ
    Barton 2500+ | Abit NF7-S 2.0 | Corsair 256mb PC-2700 C2| Jetway 9800 Pro | Maxtor 40gb ATA133
  2. #32
    Apr 2002
    Canada
    Actually, I've got quite a few, but I'll start off by asking you, if you had no limit on the amount you buy, what parts would YOU get?
    (just water, no pelts though )
    More questions to come.
    Desktop: AMD Athlon X2 4400 | DFI Lanparty nF4 SLI-DR | 2GB OCZ PC4000 EB Platinum Edition | eVGA 7800GTX | Gateway FPD2185W | 2x Maxtor 250GB 16MB SATA RAID 0 | Sound Blaster Audigy 2 ZS Gamer | Hiper Type-R 580W
    Coming Soon: Intel Core 2 Duo E6600 | ASUS Striker Extreme Nforce 680I | 2GB Corsair XMS2 8500C5D | eVGA 8800GTX | Sound Blaster X-FI FATAL1TY FPS | OCZ GameXStream 700W | Windos Vista: Home Premium
  3. #33
    Rolla, Missouri
    The exact parts I've recommended you.
    Also, with your future questions, could you keep them all in this thread as you have done so far. This thread is starting to become a good reference for watercooling beginners. I'd like to refer people to this link. It would be neat having a start to finish watercooling project in one thread. Alot of the answers to beginner's questions would be here.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  4. #34
    GSD on patrol kenrippy's Avatar
    Orange Co. CA
    pyro, you should just make a webpage or something. and build a damn w/c rig why don't you....so we can call you "hydro" instead of pyro. j/k
    Q6600 "G0" @ 3.6ghz (400x9) - tuniq tower - IP35 Pro - 4x1gb ballistix ddr800 - Thermaltake W0128RU 650w - 2x74gb raptors raid-0 (OS drive)
    heat ebay
  5. #35
    Apr 2002
    Canada
    sure, actually, that's what I intended
  6. #36
    Rolla, Missouri
    Thats the next thing on my list to do.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  7. #37
    Rolla, Missouri
    speed freak, here are some answers for your future questions.
    Water flow: Pump ---> heatercore/radiator ---> CPU waterblock ---> NB waterblock ---> GPU waterblock ---> Reservior/bleed tube ---> back to the pump.
    Its exactly like kenrippy's.
    Bleeding your watercooling system
    Heatware feedback
    Ebay feedback
    EOC Feedback
  8. #38
    Apr 2002
    Canada
    you read my mind there
    I was just thinking of that last night. Like, what to connect first (I honestly thought that the Rad would be before the pump, but I guess the pump itself creates heat, right?) Also, I have a list of tings to ask
  9. #39
    Rolla, Missouri
    ...and I have a list of things to answer.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  10. #40
    Apr 2002
    Canada
    ok, first off, what case would you recommend to use with a setup like this (I'm assuming a soho server or something.
    Secondly, is it possible to store the tank, and all in the case? if so, should I do it that way?
  11. #41
    Rolla, Missouri
    Since I've never actually built a watercooling system this is where my advice becomes somewhat limited.
    Pretty much any full tower Antec, Enermax, etc. would be able to fit all of the supplies if you did some hacking, cutting, and drilling. Which you'll have to do anyways. You'll have to remove the lower harddrive rack to fit the dtek heatercore in front under the other harddrive rack. If thats where you want to place it.
    Examples:
    Chieftec/Chenming Aluminum Dragon Case - Black $79.00 no PSU.
    Chieftec Server tower DX-01BLD,SPX-2 $73.00 shipped.
    CHIEFTEC Server Chasis (Workstation Tower) Model DX-01BD-420W Comes with a 420 watt PSU, which you probably don't need. $78.00 shipped. Thats a good price with a 420 PSU.
    Find afew cases you like then provide links to them.
    Also, kenrippy...does the tank-o-matic support 1/2 fittings? The installation guide states "This includes the installation of any fittings needed to route the water tubing to flow to the new position of the Tank-O-Matic." So I'm assuimg it does. I couldn't really tell by the pics provided and the guide never actually stated fitting sizes.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  12. #42
    Apr 2002
    Canada
    I'm actually interested in this one because of it's sheer size.
    one big arse case
  13. #43
    Rolla, Missouri
    Thats a very good case also. nikhsub1, over at oc-forums.com has that exact case and highly recommends it. Here a link to the THREAD which contains pictures of his WC system.
    There would be no remove of a second harddrvie rack, but you would need to remove the metal beam that runs horizontally under the first harddrive rack.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  14. #44
    Apr 2002
    Canada
    Thanks man, I was looking for a place and price tag for that
    Also, would cooling be more or less effective if I split the tubes from the pump the the components (that y thing) and then join them after they have gone through the system and when they connect at the tank. or is 300GPH enough to keep the whole system cool with out doing that?
  15. #45
    Rolla, Missouri
    Sorry, but I'm somewhat confused by what you meant. Could you post a waterflow direction like I had earlier or provide a generic looking paint program pic.
    Ex. Pump ---> Heatercore ---> CPU waterblock, etc.
    Are you talking about a y-splitter? If so, I wouldn't not recommend it and I don't see how it would be possible. I wouldn't split the waterflow. I'm going to email you a pic of the waterflow to your hotmail account.
    Yes, a 300GPU pump would keep the system cool without spliting.
    EDIT: The file is too big to be sent through hotmail. I'll send it to you when your on AOL.
    Heatware feedback
    Ebay feedback
    EOC Feedback
