Watercooling info - Page 4
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 99
Thread: Watercooling info
  1. #46
    Apr 2002
    Canada
    sorry about not being too clear, but yes, that is what I meant (Y splitters ) So, the heat from the CPU, and NB, won't really affect the possibilties of the cooler temps for the GPU?
    Desktop: AMD Athlon X2 4400 | DFI Lanparty nF4 SLI-DR | 2GB OCZ PC4000 EB Platinum Edition | eVGA 7800GTX | Gateway FPD2185W | 2x Maxtor 250GB 16MB SATA RAID 0 | Sound Blaster Audigy 2 ZS Gamer | Hiper Type-R 580W
    Coming Soon: Intel Core 2 Duo E6600 | ASUS Striker Extreme Nforce 680I | 2GB Corsair XMS2 8500C5D | eVGA 8800GTX | Sound Blaster X-FI FATAL1TY FPS | OCZ GameXStream 700W | Windos Vista: Home Premium
  2. #47
    Rolla, Missouri
    So, the heat from the CPU, and NB, won't really affect the possibilties of the cooler temps for the GPU? Hardly, performance would probably be worse with a Y splitter(s).
    Sharky Extreme 3DMark Team
    3DMark01 = 9700 PRO 18330
    Heatware feedback
    Ebay feedback
    EOC Feedback
    Opteron 144 | AsrockDual-SATA2 | Corsair (2x512mb) PC-3200 Value | Gigabyte X800XT PE | Seagate Barracude 80 GB SATA w/NCQ
    Barton 2500+ | Abit NF7-S 2.0 | Corsair 256mb PC-2700 C2| Jetway 9800 Pro | Maxtor 40gb ATA133
  3. #48
    Mako Shark mellojoe's Avatar
    Arkansas
    That LiteOn case (the FS020) is huge. I've been keeping my eye on it for just that reason. It isn't all that tall, per se, but it is definately wider than most standard "ATX" cases.
    The nice thing is you can mount a very decent sized pump NEXT to the standard harddrive cage. There is that much room on the side of it. There is also a secondary harddrive cage up near the rear exhaust fan, underneath the power supply. That is a great place to put the pump, too, as it can be supported on the side and bottom of the pump, for safer moving (if you move with your w/c setup inside the case).
    The case also comes with 3 stock 120mm fan slots. Yes, 3 120mm fan openings. The front bezel has that great cover over the 120mm that allows air to flow behind and is just BEGGING to be modded (I'm envisioning a mini-cutout with a small cold cathode ).
    There is plenty of room to mount all your w/c gear in there.
    The way I'd do it if I had the $$$:
    I'd mount a medium-sized resevoir in the rear harddrive cage under the power supply. Behind it, in that 120mm hole, would be a low-speed Panaflo 120mm. In the 120mm below that would be a BIX (Black Ice eXtreme) radiator with a 120mm fan (again, probably a Panaflo low or medium). Mount your waterblocks (I'd want to do at least CPU and GPU, but I'm not terribly concerned about w/c northbridge). The front 120mm would be open for a 3rd Panaflo medium/low speed 120mm fan.
    That way you have decent air moving, very minimal noise, and great cooling.
    mellojoe
    Knight of the OC Crusades
    --in the Lian Li A16--
    DFI LanParty DK P35 T2RS
    Intel E7200 (2.53) @ 4.0 ghz
    G.Skill 4GB DDR2-1000 5-5-5-15
    Corsair 750W
    evga 9800GTX+
    Lite-ON 20X DVD±RW DL
    --watercooling--
    D-Tek Fuzion v2
    Swiftech MCP655
    2x120mm BIX GTX
    Swiftech MicroRes
    __________
    ________
    ______
    ____
    __
  4. #49
    Apr 2002
    Canada
    Thanks guys, I'll actually try to draw an image later on and show you my palns (as for Y, I will ditch it then) Also, I want to have a NB because I want HIGH FSB speeds and mem speeds.
  5. #50
    Apr 2002
    Canada
    sorry, was tied up today, I'll have one by tomorrow
  6. #51
    Tiger Shark Sinnersis's Avatar
    Melton Mowbray, England
    Speed freak I suggest you vist the other thread in this forum:
    http://www.sharkyforums.com/showthre...02#post1203402
    Number1sixerfan has given me some brilliant links (I'm also new to water cooling) and from what I've read peltiers are not to be ignored. (Look at the temps number1sixerfan has quoted ).
    Also thanks to Pyro and Kennrippy for the info provided.
    Tempus Edax Rerum
    (2^43,112,609)-1 is Prime
  7. #52
    remember me? number1sixerfan's Avatar
    Sep 2002
    Ohio
    Originally posted by Pyro
    speed freak, here are some answers for your future questions.
    Water flow: Pump ---> heatercore/radiator ---> CPU waterblock ---> NB waterblock ---> GPU waterblock ---> Reservior/bleed tube ---> back to the pump.
    Its exactly like kenrippy's.
    Bleeding your watercooling system
    With a fill & bleed assembly do you need an airtrap, reservoir, or none at all?
  8. #53
    Apr 2002
    Canada
    Originally posted by number1sixerfan
    With a fill & bleed assembly or do you need an airtrap, reservoir, or none at all?
    sorry, I really am clueless to what you are talking about
    I would like to know the difference between keeping it in a tank, and "bleeding" would you not need a tank still?
  9. #54
    Sep 2002
    Ohio
    Sorry for the confusion, but I am not sure whether or not you still need a reservoir with a bleeding assembly. I thought you didn't. Anyone know?
  10. #55
    Rolla, Missouri
    At first in the thread I thought the fill/bleed tube was the right way to go. But after checking out the reservior kenrippy had, I recommended speedfreak the tube reservior instead.
    In the below flow chart, I had included both options of where the reservior or the bleed tube should be placed, not both.
    Sorry for the confusion, I didn't really state that in earliar posts.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  11. #56
    Sep 2002
    Ohio
    So you don't need both. It's either reservoir or fill & bleed assembly, correct? What's wrong with the fiil & bleed assembly?
  12. #57
    Rolla, Missouri
    Correct
    Nothing at all. I just think the tube reservior looks more professional.
    Heatware feedback
    Ebay feedback
    EOC Feedback
  13. #58
    Sep 2002
    Ohio
    Ok glad to clear that up. With a bleeding assembly there is no maintenace, so I think I'll go down that route. I saving up for A swiftech based WC rig.
  14. #59
    GSD on patrol kenrippy's Avatar
    Orange Co. CA
    hey guys, sorry i've been out of town for a few days.
    regarding the Innovatek "Tank-O-Matic" reservoir and 1/2" tubing. I've seen it done before by using it without the retainer nuts that tighten and make the seal. you just slip the 1/2 tubing over the whole fitting and use a hose clamp or large zip tie to make the seal. It's kinda iffy if you ask me though.
    also on the tube type reservoir, the main thing is to have the INLET hose or tube way down low in the water so the air bubbles will not be sucked back into the lines. and have the OUTLET tube (the one that goes into the res) a couple inches higher than the inlet tube. the way Innovatek designed theirs is absolutely perfect. it makes for a guraanteed air gap:
    Q6600 "G0" @ 3.6ghz (400x9) - tuniq tower - IP35 Pro - 4x1gb ballistix ddr800 - Thermaltake W0128RU 650w - 2x74gb raptors raid-0 (OS drive)
    heat ebay
  15. #60
    Apr 2002
    Canada
    so the water would drop down?
    also, so, a res. would be great, and I would not have to learn this new thing on bleed (how to do it) ?
    I want to thank you all for helping me out, as I am still in the dust as what this and that is and so on.
