GSD on patrol
the water line on that res pictured above would be over the top of both tubes. (see my pics) it's just that the much smaller intake tube would allow any air bubbles to not be sucked back into the system. thus creating a SELF BLEEDING system. so if you have a res like this or similar you won't need any bleed tubes or anything like that. bleeding is another word for removing air.
Q6600 "G0" @ 3.6ghz (400x9) - tuniq tower - IP35 Pro - 4x1gb ballistix ddr800 - Thermaltake W0128RU 650w - 2x74gb raptors raid-0 (OS drive)
heat ebay
GSD on patrol
T line
this pic is of a "T" line added to a system that doesn't have a res. this is used for a bleed/air gap instead of a res. the purpose of this is so the air will be trapped in the top of the T where it can't get into the main system. you just put a cap on the top of it and also fill your system from there. it's best to have the top of the T line near the top of the case.
heat ebay
so, if I do the tubular way, then there is pretty much no maintanance?
Desktop: AMD Athlon X2 4400 | DFI Lanparty nF4 SLI-DR | 2GB OCZ PC4000 EB Platinum Edition | eVGA 7800GTX | Gateway FPD2185W | 2x Maxtor 250GB 16MB SATA RAID 0 | Sound Blaster Audigy 2 ZS Gamer | Hiper Type-R 580W
Coming Soon: Intel Core 2 Duo E6600 | ASUS Striker Extreme Nforce 680I | 2GB Corsair XMS2 8500C5D | eVGA 8800GTX | Sound Blaster X-FI FATAL1TY FPS | OCZ GameXStream 700W | Windos Vista: Home Premium
GSD on patrol
i don't see any maintenance either way. it's just harder to get all the bubbles out with the "t" setup. figure the water jetting by the "t" and some of the bubbles won't make it up the t-line because of the speed of the water. it will take longer to bleed the system that way. with a res like that tank-0-matic the bubbles bleed first pass thru.
heat ebay
why cheaper?
it pushes more water, and sounds good, am I still better off with the enheim (sp?)
GSD on patrol
why cheaper?
from what everyone says, Eheim is the standard by which every other brand of pump is measured. reliability, noise, heat etc. but reliability being the most important.
heat ebay
Alot of people highly recommend the Via Aqua Pump. Its not a bad choice, but as kenrippy said "Eheim is the standard by which every other brand of pump is measured. reliability, noise, heat etc. but reliability being the most important."
Thanks, I'm heading out for a bit today, but I have just a few more things to confirm before I order.
sorry for bringing this thread back, but I just need to clarify a few more things
1) what tools do I use to mod the case?
2) any new parts coming out by Dec. or Jan. that I should worry about?
3) would it be possible to put the rad. in the hard drive rack at the top in the back and just drill a hole out of there, so the warm air travels out instead of through the case?
Kinda what I was thinking of
OR, whould that affect the cooling of the water
I'm confusing myself now
GSD on patrol
hey speed freak,
The one thing I see that needs some change is the rad air flow should be sucking fresh air in. not having case air going thru your rad. and it might get a bit warmer up near the psu it will be the warmest thing in your case. by the looks of your drawing, you might want to go with what I did. just a few thoughts....btw when are you gonna build this thing?
heat ebay
I was intending to put the radiator on my system above the PSU (In a Lian Li PC 70) and put two fans in front of the radiator and two fans behind (or something to that affect).
I can't use the space where the intake fans are since I will need that for hard disks. Any opinons / suggestions on that Kenrippy (or someone)?
Thanks again
remember me?
Thanks again
What type of radiator are you gonna use?
Originally posted by kenrippy
hey speed freak,
Ok, thanks
BTW, I have until late Dec. to early Jan. but I wanted to clear all this up as aoon as I could.
