Results 1 to 7 of 7
    Another Headphone thread :D gaming, and portable cd player
    I'm looking for a pair of headphones that will suit all my needs.
    They need to have strong bass for gaming.
    They have to be comftorable!! and able to breathe so my ears don't sweat.
    They also have to be able to "keep the sound in" for quite places, such as the library, or an airplane.
    They have to be under $80.
    They don't need an amp to sound good, something my rio volt can handle.
    They need to be durable.
    I have a Sound Blaster Audigy, and play games like Soldier of Fortune 2. The type of music I listen to is mostly rock: System of a Down, Korn, Red Hot Chili Peppers, Rancid, Godsmack, Disturbed, Korn, etc.
    Is there such a pair of headphones?
    I've heard the Sennheiser HD 497 ones are good, but do they meet all my qualifications.
    Is it even possible to have a pair of headphones that breathe, yet keep the sound in?
    I think that's it
    Oct 2002
    headphone.com has some nice info...
    Hammerhead Shark Mr Roboto's Avatar
    Durham, NH, USA
    I have and love the sony mdr-v300
    I pulled the sword from the stone...
    P4 3.00Ghz - 512Mb hypermax4000 - Abit IC7
    365Gb 7200 HD
    [color=dark orange]9700pro - 21 inches of FD Trinitron bliss[/color]
    Platnium Audigy with live drive
    Klipsch 5.1 speakers
    "I'm blind! Sweet Crackers! I'm utterly blind!"
    OC Knight of the OC Crusaders
    Tiger Shark Nasty's Avatar
    Oct 2002
    Melrose Park, Illinois, USA
    If you're going to spend the same amount of $$$ that the Sony MDR-V300 costs, I'd recommend the Sennheiser HD 212 PRO instead. Both sell for about the same price at a given reseller -- but the Sonys sounded just plain muddy (based on my previous experience with that model). The V300 delivers WAY too much mid- and upper-bass response, with almost NO low bass to speak of. The midrange is almost nonexistent on the V300, as well. And the highs? Well, grainy as @#$%, to boot!! Worst of all is that the headband itself will break in almost no time, and they're uncomfortable as hell!!!
    The HD 212 PRO sounds dark, to be sure. But at least it doesn't suffer from all of the inaccuracies that most of the MDR-V### series 'phones have been suffering from.
    MY CURRENT RIGS:
    Main Rig: Intel Core 2 Duo E6750 processor, Intel DP35DP, 2GB Corsair TWIN2X2048-6400C5DHX kit @ DDR2-800/5-5-5-18, BFG 8800GT OC PCI-e @ factory-set clocks, 500GB Seagate 7200.10 SATA hard drive, Samsung S203N SATA and Lite-On 160P6S IDE DVD burners, X-Fi XtremeMusic
    Guest Rig: Intel P4/2.8C, Intel D865PERL, 2GB PC3200, GeForce 6800GT AGP, WD1200JB, Sony 810A DVD burner
    Out West
    Re: Another Headphone thread :D gaming, and portable cd player
    I think that's it
    I just got a set of 497's and my feelings are mixed. As far as the audio aspects go, I am quite pleased. I will have to throw away most of my mp3's now because I can hear all the defects, which I could not with my Yamaha RH5MA's or my Z-560's. The positioning of sound is very good, which is critical in fps games, which I play a lot of. It's much easier to tell where sound is coming from now. As for bass response - well, I can hear everything in the phones I can hear on my 560's when I run the THX Ultimate Bass Test. Like I said, I'm pleased with the audio. Where I am not so happy is in the construction and comfort of the phones. The construction is cheap molded plastic. The Yamaha's I replaced, despite being much lower in terms of sound quality, were far better built. It suprised me that they would build such cheap fixturing for such decent phones. Also, at least at the moment, they squeeze my ears enough to become uncomfortable after an hour or so. But, all my other sets of headphones have too, so that's not too big a shock. Still, I was hoping...
    Overall, for $50 I'm happy. I'd rather have gotten the same speaker elements in a sturdier and more comfortable setup, even if it cost twice the price, but these are pretty good for the money.
    One by one, the penguins are stealing my sanity.
    I agree with Nasty on the Senn HD-212 pros. Those or perhaps the Sony MDR-V6 not the V600.. the V6. They're both closed and can be had for less than $80.
    I just want to make a quick comment about headphone use. You really shouldnt be wearing them for more than an hour or so at a time anyway. It's quite easy to get 100db at that range which means that after 2 hrs you can damage your ears... permanently. The frequency response on your headphones or speakers won't mean much if your ears can't pick them up. Just take a break every once in a while.. your ears will thank you.
    WinXP Home
    AthlonXP 1800+ w/stock hsf
    Shuttle Ak31a
    PNY(Samsung) pc2100 256mb
    Visiontek Geforce4 4200 128mb
    Turtle Beach Santa Cruz
    WD 40gb ata100 7200rpm
    Toshiba 16x/48x dvd
    Lite-on 32x12x40 cdrw
    Monsoon MH-505 5.1
    Grado SR-60
    17" Samtron
    Lian-Li PC-60
    Hmm thanks for the opinions guys. Yeah, I'm really looking for some really comfortable headphones with good bass for gaming. I've decided to scratch the idea of closed headphones because I've learned that they don't sound as good as the opened ones, and will probably make my ears sweat less.
    So does anyone know of any really comfortable headphones with good bass for under $80.
    Thanks
