Results 1 to 15 of 15
    Catfish MisterTurret's Avatar
    NY State
    How to Reformat?
    I know this is a dumb question, but how do you reformat out of XP? I put in the install disk and there is no option to reformat in the install...How do I get to the command prompt without starting the install so I can format ALL of my disks.
    Hammerhead Shark posthumous_GRIN's Avatar
    Use fdisk to delete your partitions first so there are no traces ao any old system, change the BIOS to boot from CD and put the XP disc in.
    Or.
    Download the boot discs from MS's site and use those.
    Or.
    From within windows, put the xp disc in your drive and check install windows xp or whatever the first option is and follow the prompts. I just did this two days ago so give it another try...
    Hammerhead Shark Ra\/eN's Avatar
    Styx River, Just North of Barathrum
    NY State
    This is terrible. I cant create the disks because the program says they are write protected, even though they ARENT. Fdisk doesnt work, it just tells me to take out the media and restart the computer...This is hopeless. Im using WinXP Home
    Pennsylvania
    Get a Windows 98 boot disk or something and boot from that.
    Lian Li PC60
    OCZ Modstream 520
    Asus M3A78
    Athlon 64 X2 5000+
    OCZ Platinum 2x 1gb PC8500
    Western Digital 36G Raptor
    Western Digital 200G SATA
    Western Digital 640G SATA
    XFX Geforce 7900GT
    Acer F-22
    Windows Vista Ultimate SP1
    A+ Certified
    Network+ Certified
    NY State
    I boot from Win98 Boot Disk, it shows NOTHING on c: and says it cannot be formatted...messed up. Setup disks for XP are still giving me errors half way through the setup...its MESSED UP. I cant format my hd
    Catfish TheGreatGoat's Avatar
    Dec 2002
    WI
    Download the utilities from your drives manufacturer and use those to write zeros to the drive.
    <H1>Johnny D</h1>
    If you really feel you are running out of options, go buy new discs (you will need 6), download the boot prog from MS's site and load up the discs, that has to work...
    NY State
    I don't remember..does the XP setup have options for deleting partitions and formatting them before you install again?
    Pennsylvania
    Yea you can just do a clean install.
    Lian Li PC60
    OCZ Modstream 520
    Asus M3A78
    Athlon 64 X2 5000+
    XFX Geforce 7900GT
    Acer F-22
    A+ Certified
    Network+ Certified
    Upstate New York
    Yes. At the part you select which partition to install to, you can also select to delete and/or create partitions.
    sorry.. try here
    http://support.microsoft.com/default...310994&gssnb=1
    the last and desperate option is getting a wipe utility from your hd maker.
    for example... maxtor uses this to completely wipe their hd's
    max blast II
    http://www.maxtor.com/en/support/dow...st_plus_ii.htm
    and this for diags
    http://www.maxtor.com/en/support/downloads/powermax.htm
    ohio
    Originally posted by Ra\/eN
    sorry.. try here
    max blast II
    and this for diags
    With maxblast II figure in plenty of time. An 80 gig took 4-5 hrs. Seems too do the job though
    Thank you sir. May I have another?
    NY State
    I have a Maxtor AND an IBM Deskstar. Can the Maxblast wipe both of the drives?
    Dec 2002
    WI
    Are you running the drives in an array? No the utills must come from both drive makers.
    <H1>Johnny D</h1>
