Results 1 to 8 of 8
Thread: system lockups
    cherry hill,n.j.
    Angry system lockups
    while on the internet my system locks up. it doesn't lockup when not on the internet. it started when i put in a dvd drive& cable modem.
    Kamloops, BC, Canada
    Smile
    Try getting the latest drivers for your network card. Also try getting the latest BIOS update for your motherboard.
    No Matter Where You Go, There You Are.
    My problem is the same. The only lock-ups I get is when I am on the Internet. I use an external ISDN modem (USB)and whas thinking it maybe is the PSU??? I only have a 230w PSU.
    Bla, bla, bla, bla...
    Hi, I can't see why the DVD would do anything to cause lockups while on the internet.
    Most likely its the cable modem. Are you using an anti-viurs program? Does the cable modem have a built-in firewall?
    Regards,
    Camper
    Registered User
    Atlanta, GA
    Regards,
    Camper
    A good friend of mine had a similar problem with his DVD/IDSN setup. If he removed the DVD, the problem went away. I don't know if he ever found an alternative solution.
    "Everyone knows the best bands are affiliated with Satan."
    Lightbulb
    This just a guess; Go into the bios and assign an IRQ to VGA(if available). Then reset ESCD configuration data. I'm assuming you're using software as the decorder so the DVD uses the Vid card. Actually try this first, go into System properties, under Performance. Click on Graphics and move slider to None. Let me know what happens.
    Tech GOD
    Tech GOD
    Miami, Fl USA
    Make sure that your cable modem is not sharing IRQ with any of your other card also update the drivers for the cable modem and check for a firmware update for the DVD drive
    Springfield
    does the mouse remain active during the lockup? or does the system completely freeze? if it is a complete freeze this probably won't help. The case that I had the dvd and the NIC were sharing one Input/Output range that only seemed to cause a problem when recieving udp traffic. I just ended up removing the NIC and installing the latest drivers and reinstalling direct x and all was good.
    Keep honking I'm reloading.
    I do not have multiple personality disorder...my doctor says we are getting much better.
