Ok, my little HDD is FAT32 whilst my main one is NTFS, if I format the smaller one into NTFS will it screw anything up? Will it make transfer between the drives faster?
Thanks.
Main Rig
+ AthlonXP 2500+ Barton (early week, unlocked); cooled by SLK900A w/ 92mm 64cfm fan + The Uberduct
+ 200x11, 1.725vcore, 2.7vdimm for everyday use; 210x11, 1.825vcore, 2.8vdimm max stable overclock
+ Abit NF7-S rev2 (Vantec Iceberq on NB)
+ 1x512MB Buffalo Tech PC3200 (CH-5)
+ Radeon 9500 Pro awaiting it's overclock
+ Seagate Barracuda 80GB 8MB cache 7200RPM HD#1
+ Western Digital 60GB 2MB cache 5400rpm HD#2
+ LG 52x CDRW
+ Samsung 32x CDROM
+ Allied 400W PSU
+ NEC FE991SB 19"
+ WindowsXP Proffesional
+ Sennheiser HD212 PROs
I change like that has the possibilities of destroying all your files. But it’s generally a piece of cake to convert. File transfers will be better but it’s not going to knock your socks off.
I am in the same boat, except that I just did a fresh install of windows xp pro on my AMD system. I split the drive (fresh format) into two sections and windows made the first section ntfs as I installed on it. Now I want to make the second part ntfs too, how do I do that?
System 2 (Just built):
Epox 8RGA+
XP 2400+
512 MB KingMax DDR 400
80 GB WD 8 Mb
Originally posted by Captain Hook I am in the same boat, except that I just did a fresh install of windows xp pro on my AMD system. I split the drive (fresh format) into two sections and windows made the first section ntfs as I installed on it. Now I want to make the second part ntfs too, how do I do that?
Open up a command prompt and type:
convert [drive:] /fs:ntfs
Where [drive:] is the drive letter to be converted.
Intel i7 3.2GHz @ 3.93GHz
Would this be safe/posible on the drive that was running the OS. Say I had XP on a fat32 but I want to take it to NTFC, can I with this command or should I use PM.
ASPIRE X-QPACK/ENERMAX EG425P-VE(420W)
MSI K8NGM2-FID
A64 3700+ San Diego/ZALMAN CNPS7000B-ALCU
G.SKILL Extreme Series 2GB (2 x 1GB) PC 3200
C3D X800GTO/ATI Silencer5 Rev.2
2x Seagate Barracuda 7200.9 160GB 7.2K 8MB SATA 3.0Gb
LITE-ON 1635S
Yes, it works on the drive that has the OS on it. The command will say that it cannot lock the drive to perform the operation and will ask if you want to convert upon the next reboot.
