Best Nvidia driver for Geforce 2 Ti
I recently installed 43.45 drivers for my geforce 2 Ti. but the system was not able to complete the 3DMark 2001 after that.. i switched back to Windows XP default driver it managed to complete the test.. but even with incomplete test in 3DMark 2001 i managed to score 3000 score with 43.45 drivers.. but with default windows driver even completing all the test gave only 2000 score..
i then installed the 44.03 drivers but they also crashed in the 3DMark 2001. i read the fine prints and realised they are only windows certified for the geforce FX cards not for the earlier geforce..
so rite now i m running the system with the default drivers which are not giving any performance. so can u kindly tell me which are the best drivers for the Geforce 2 Ti card. and where to find them.. i didn;t find any previous driver on the nvidia site.
Thanks...
Try the 40.72`s or the 30.82`s.
i7 920 @3GH, P6T Deluxe V2, OCZ HP 6GB(3x2)Kit(7-7-7-16), 128GB Patriot SSD, 250GB SATA(7200)Hitachi, WD 500gb, 1000W BFG PSU, SATA Pioneer DVD CD burner, XFX5870 XXX edition(900/1300), LG LED 2350V, XFI Titanium Fatal1ty champion, Logitech X-540, Lian Li PC-B70 Full Tower Case, Win7 HP.
Do you have DirectX 9 installed?
Intel i7 3.2GHz @ 4.24GHz
HIS R9 290X @1050MHz
Cross posting is bad...shame on you. Anyways, 23.11 or 23.12.
MSI K7N2G-ILSR Nvidia nForce2 | 384mb Crucial PC2100 | ThermalRight AX-7
Athlon XP 1700+ 2269mhz 12*189, 1.85v | Midiland 7100+ speakers
PNY Geforce4 Ti4200 64mb 305/645 w/Zalman HP-80A
Seagate Baracudda IV 40gb HDD | Seagate Baracudda V 80gb HDD
Hitachi GD-2000 2x DVD | Liteon 48x12x48 CD-RW | Dell 1800fp monitor
Fortron 300W PSU w/120mm fan | Leadtek 2000xp Deluxe tuner card
Laptop: Inspiron 5150 3.06ghz | 640mb pc2700 | 30gb hdd | 64mb Radeon 9000 | 15" sxga+ | CDRW-DVD
Sharky Extreme 3dmark team - http://www.irydium.net/3dmark/
No i m using DirectX 8.1
currently downloading 40.72
will update u later.
Of the two the 23.12s performed best for me. That's what I'd recommend you use.
Downloaded 40.72
Result... Crashed yet again.. on the same Pixel Shader test..
Is it possible that part of my Geforce 2 has got burned..?
or the problem is somewhere else..??
But how come windows default driver run the entire suit without any crash...
I don`t think its your video card, it could be something running in the background or you did not get rid of all traces of the old drivers in the reg. I have had no problem like that using the 40.72`s on my GF2 MX.
id uninstall the drivers, dont reboot yet, use det destroyer, then reboot and reinstall the 40.72's..
they worked well w/my gf2 gts's..
Thanks a lot.. i have installed the 23.12 drivers and its working fine after that...
my score has also gone upto 3000. anyway might try the 40.72 after using det destroyer... actually it takes a lot of time downloading on modems.. so thats y a bit slow in updating..
