Random Blue Screens in XP Pro
Results 1 to 6 of 6
Thread: Random Blue Screens in XP Pro
    Jun 2003
    UK
    My system seemed stable. Except totally randomly it will crash to a blue screen of death with a random incomprehensible error message. ie bad pool spooler, there are others but nothing consistent. I'm am never doing anything special or loading anything at the time, nothing particular is open, its completely random. Any ideas?
    The stop code, a hex number following the word stop is the key to determining what the problem is. You can search for causes, workarounds and fixes on the MS Knowledgebase using the stop code.
    Have you checked your system event log for warnings and errors?
    The logs can be viewed with Event Viewer accessed via the Computer Management MMC.
    Old School OCer OS-Wiz's Avatar
    St. Louis, Mo, USA
    That is a classic sign of bad memory, but you never know. Download memtest and see what happens. http://www.memtest86.com/
    Mako Shark coolqf's Avatar
    New York, NY, US
    Had a similar problem once as he mentioned. I was bored one day and set the BIOS settings to optimal default. Problem disappeared....
    Texarkana, TX
    Should memtest run on a Canterwood board (ASUS P4C800) if everything is okay?
    Texarkana, TX
    Recently had a similar problem on an ASUS P4C800 Dlx -- turned out to be bus contention issues between the SATA RAID and another installed PCI bus mastering controller.
