11-13-2003, 01:07 PM
#781
Folding Team Member
Originally posted by ace727861986
could someone explain why this portein has 500000 steps? p801_p53dimer801? I know nothing about F@H so dont laugh. Is this a large wu to process or small or what? How long should it normally take? BTW i might like this so i might actually build me a farm if my parents dont get all pissed off about how much electricity its going to use :/.
I assume you read the log file and saw you were at 0 of 500000. 500000 is what we call a 500. If you hover your mouse of the red icon next to your clock it will show you at 0/500 or wherever you're at currently. That will net you 32 points when you finish it. According to your log file your frame will be 1% or 5000. So 5000/500000. This would be considered a mid-size WU. How long it takes will depend on your cpu. If you got over 1Ghz it'll take less than a day; over 2 Ghz less than 12 hours.
11-13-2003, 01:22 PM
#782
Sleeps with the Fishes
This takes a while mine has been folding a 400 for a few days then again it hasn't always been on. Once it's done folding this one, will my name appear online?
11-13-2003, 01:25 PM
#783
Yes, it will appear on the team's site.
11-13-2003, 01:26 PM
#784
Folding Team Member
Yeah once you finish the WU stanford adds you to our page. The 400's are those 71 point Tinker WU's you truly don't want those they will take you over 36 hours even with 3GHz+ P4. What you wanna do is refer to the Folding FAQ sticky below and you must add -advmethods to your shortcut target line. This will enable you to receive Gromacs WU's which leverage SSE. With your cpu and -advmethods so you get Gromacs WU's you will be churning out closer to 100points per 24 hours or roughly twice what you can do with those Tinker WU's
11-13-2003, 02:02 PM
#785
Resident Audiophile
Sap, mine won't let me add -advmethods to my desktop shortcut. You mentioned something about the Beta version? I'm not running that, actaully, here is a screenshot for ya Maybe I can just download the Beta if the version I have is really holding me back.
11-13-2003, 02:16 PM
#786
Folding Team Member
Congrats on the 5K
Are you sure if you were able to highlight the target line you should be able to click your cursor there and type. Also rather than a desktop shortcut I'd place the shortcut in the startup folder
11-13-2003, 02:24 PM
#787
Resident Audiophile
Thanks
Yeah, I took care of it. I just put it in the startup folder and it's fine
11-13-2003, 02:25 PM
#788
Old School OCer
XP18004life -- 5K posts -- Congrats
11-13-2003, 02:29 PM
#789
i got a 400 overnight and it's up to frame 150 -- how many frames do they go to? 400?
workstation: athlon xp-m 2400+@2.4Ghz | epox 8rda+ | 512mb | seagate 80gb+160gb | arch linux
web server: athlon xp 1600+ | epox 8k3a+ | 256mb | maxtor 30gb | debian linux
11-13-2003, 02:31 PM
#790
Folding Team Member
Originally posted by XP18004life
Thanks
Its fine as in you now have the -advmethods?
BTW XP remind me if you have Intel or AMD?
BTW to everyone on the latest ExtremeOCing we just passed Hardware Wiz this I consider a major victory. They are the #2 team behind us of the teams #200-1000. After our first week of existence we were already #2 behind them. Thinking small I set a target to match their output. That obviously didn't take long as we are now doubling their production. Well done everyone. Conquer On
11-13-2003, 02:32 PM
#791
Folding Team Member
If you're getting 400 framers you're getting Tinker WU's which means you're not using SSE and you're really going to be handicapped. Refer to the FAQ on how to solve this issue/problem.
11-13-2003, 02:35 PM
#792
Resident Audiophile
Sap, my lappy is a 900mhz P3 and my main rig is a 2100+
edit: It's not working now. Remind me where my "real" startup folder is because I copied it to the wrong one
11-13-2003, 02:39 PM
#793
Folding Team Member
Then you're is still not optimized; cause you got the 3.24 right? Refer to the Folding FAQ on how to solve your problem. Basically you need to go back to stanford and get the beta. You'll like get v4. Then shortcut it and add the flags -advmethods and -forceSSE just for you amd . Place it in the startup folder. Now you will also want to delete any cores that are currently in your Folding@Home folder and reboot. You'll have to quit the client to do all this so if you're too far into a WU wait till it finishes and then do it
#794
i was already running the SSE and advmethods. the problem is i had accumulated two cores, and i didn't know which one it was using. so during some disk "housecleaning" i deleted both thinking fah would just d/load a new one the next time around. well, it did that, but apparently it didn't keep the flag settings when it engaged the new core and i got stuck with a tinker.
i just want to know how many frames it goes to, b/c at 6 min per frame, that still leaves 36 hrs left on this one WU. even if i delete it now and lose the work it's done, i'll be ahead when i can reset the command line and start getting gromacs again. i'm assuming it goes to 400, but i just want to make sure.
11-13-2003, 02:41 PM
#795
Folding Team Member
In WinXP click all programs and it should be there right click startup to open the folder
