11-13-2003, 02:43 PM
#796
Folding Team Member
Originally posted by serotone9
i was already running the SSE and advmethods. the problem is i had accumulated two cores, and i didn't know which one it was using. so during some disk "housecleaning" i deleted both thinking fah would just d/load a new one the next time around. well, it did that, but apparently it didn't keep the flag settings when it engaged the new core and i got stuck with a tinker.
i just want to know how many frames it goes to, b/c at 6 min per frame, that still leaves 36 hrs left on this one WU. even if i delete it now and lose the work it's done, i'll be ahead when i can reset the command line and start getting gromacs again. i'm assuming it goes to 400, but i just want to make sure.
Yeah its 400 it counts by 1's whereas the 500's count by 5's and the 2500's count by 25's. I'd quit the client and re-delete the 65 core you got. You'll need a re-boot after deleting the 65 core and putting your flags in your beta shortcut again.
65=Tinker
78=Gromacs
11-13-2003, 02:53 PM
#797
d@mn, this one's a 400 framer -- p692_L939_K12M_int. good-bye.
note to linux users: if you have to delete a core, restart the client with the SSE and advmethods options again, or else the optimization flags won't carry over to the new core and you could end up with tinkers.
edit: keep getting tinkers/core 65 no matter what - moved to folding problems thread.
workstation: athlon xp-m 2400+@2.4Ghz | epox 8rda+ | 512mb | seagate 80gb+160gb | arch linux
web server: athlon xp 1600+ | epox 8k3a+ | 256mb | maxtor 30gb | debian linux
11-13-2003, 04:37 PM
#798
Sleeps with the Fishes
Originally posted by OS-Wiz
XP18004life -- 5K posts -- Congrats
I'm on my way
11-13-2003, 05:24 PM
#799
are geromacs bad?
This is what i got
Project: 811 (Run 19, Clone 0, Gen 0)
Assembly optimizations on if available.
Entering M.D.
Protein: p811_p53dimer811
Writing local files
Extra 3DNow boost OK.
Writing local files
Completed 0 out of 500000 steps (0)
is that what i should have for an AMD machine? "Extra 3DNow boost OK.
11-13-2003, 05:37 PM
#800
Originally posted by ace727861986
are geromacs bad?
no, you want it to say "Extra SSE boost OK." see sap's "Howto" linked in my sig.
"geromacs" = gromacs, which is what you want. just set your flags to get the SSE boost instead of 3DNow.
11-13-2003, 05:49 PM
#801
how can i get teh 3.25 beta? all i see is 3.24
11-13-2003, 05:51 PM
#802
get the one you want in the 3.25 folder here.
11-13-2003, 06:00 PM
#803
bahhh this is getting old. its not saying SSE boost or whatever. Here is my shortcut
D:\F@H2\FAH3.25-Console-beta.exe -advmethods -forceasm
also tryed
D:\F@H2\FAH3.25-Console-beta.exe -advmethods -forceasm -forceSSE
with FAH4.00
well this even work for an AMD 1.33ghz t-bird?!?!?!
11-13-2003, 06:36 PM
#804
Running Man
lonewolf, schultz and mu_ohio y'all are officially passed up
11-13-2003, 06:43 PM
#805
also tryed
with FAH4.00
??? with FAH4.00, the command should be
D:\F@H2\FAH4.00-Console-[version].exe -forceSSE -advmethods
with [version] being Pre, Pre1, or whatever you're using
11-13-2003, 06:44 PM
#806
sorry ment
D:\F@H\FAH4.00-Console-Pre1.exe -forceSSE -advmethods
*sigh* this is really getting annoying. I have rebooted i have deleted. I have tryed diff versions. i have tryed putting -advmethods first i have tryed -forceSSE first.
11-13-2003, 06:46 PM
#807
try deleting the core. it'll be in your folding directory.
11-13-2003, 06:48 PM
#808
Ive deleted it every time i changed something. Does it matter if im using GUI or command prompt version bc im using command prompt :/?
11-13-2003, 06:50 PM
#809
Evil Monkey Shark
also tryed
with FAH4.00
Athlon thunderbirds and earlier do not have SSE, only XP chips and newer do, so for that system, no it's not going to work. i'd still put in -advmethods though, that way you get a larger variety of WU's
- 2xRaptor 150GB RAID-0
Dave? Dave?! Dave's not here...
#810
lol thanks for the info . So what do i need to put into my startup? -advmethods? and -forceSSE (i know it wont work but does it matter) -forceasm?
