Results 1 to 6 of 6
    Nov 2003
    Temps during benchmark
    Okay I know my bios shows my MB and CPU temps.
    How can I find them out in windows, or a way to log them so that I can run my computer through some benchmarks and see how the temp is holding out?
    My old asus board came with a utility to do it, but I can't seem to find one for this one.
    Current setup: Asus A7N8X Deluxe 11x@200FSB Barton 2500+
    Main Rig (Elysium): CPU: AMD64 3000+; MOBO: Abit KV8-Max3 uGuru; 2x 512MB ; GeForce 5700 256; WD 34Gig 10000RPM HD ; Lite-On 16x DVD;
    Great White Shark lonewolfroger's Avatar
    Aug 2002
    Texas
    You can get MBM5 here http://mbm.livewiredev.com and check the MB list to see which sensors to use for your MB.
    i7 920 @3GH, P6T Deluxe V2, OCZ HP 6GB(3x2)Kit(7-7-7-16), 128GB Patriot SSD, 250GB SATA(7200)Hitachi, WD 500gb, 1000W BFG PSU, SATA Pioneer DVD CD burner, XFX5870 XXX edition(900/1300), LG LED 2350V, XFI Titanium Fatal1ty champion, Logitech X-540, Lian Li PC-B70 Full Tower Case, Win7 HP.
    Mako Shark Lord Vetinari's Avatar
    Jan 2002
    Worthing Sussex England
    MBM5 will do it. Or if you run Sisoft Sandra burn in you can monitor the temps on a nice graph (although it often misallocates the temp sensors)
    With MBM5 and an A7n8X you can even set it to read the on-die temp and under cpu sensor whilst monitoring the temps of your hard drives as well. It doesn't sing yet whilst its doing it tho.
    Newest comp DFI nf2 ultra xp1500-m @223*10.5 or XP2500-M barton @230*10.5
    new comp- 8RDA+, xp2100 TbredB @202*11, 2*twinmos 3200 (non winbond), 9700 pro, Maxtor 9 plus 80gb &120GB, Hitachi CML174SWB 17" LCD
    Old comp KT7A Axia 1ghz @1.38GHZ,
    GF3 ti200, Compaq 910 19" Monitor
    Nov 2003
    Is there a reason my CPU diode temp is 0C ?
    Does this mobo not have a sensor on the diode? a7n8xdeluxe
    Under a full load (hours of gaming) what should my max temps be?
    Reef Shark Squirlenutz's Avatar
    Mar 2003
    I have the same mobo, there are sensors by the processor, just go to www.asus.com and download the Asus Probe.
    System:
    Core 2 Duo e8400
    ASUS P5Q Pro
    4 gigs DDR2 PC2 8500 Mushkin Ram
    EVGA GTX 260
    WD 74 gig Raptor
    Maxtor 300 gig Diamond Max
    Maxtor 1 tb
    Antec NeoPower 550w
    Nov 2003
    Well I get a socket temp, just not a diode temp...was wondering if that was okay or not more than anything
    Seems the best my system can do, without a lot of tinkering I guess, is 11x200. If I raise it 1mhz higher on the FSB I get some blue screen error message on windows startup that goes by too fast to read. If I raise the multiplier any it won't post correctly.
    But Honestly I guess I should be happy paying for a 2500+ and getting a 3200+ :-) Thanks everyone
