XP installation freezes at "Registering Components"
Results 1 to 10 of 10
Thread: XP installation freezes at "Registering Components"
    Expensive Sushi NaughtyDog's Avatar
    Detroit
    I am trying to do a fresh install of XP on my friends PC when about 14 minutes left while "registering components" the installation freezes. What exactly is XP doing at this time and what should I do? Any help is greatly appreciated thanks.
    Hammerhead Shark xelaeel's Avatar
    Feb 2002
    Toronto
    Did it stop for a long time? like 10 mins at that %?
    XELA!
    Athlon XP2400+ @ 2343Mhz (11x213)
    SLK 947U w/92mm Tornado w/Nexus 205
    Abit NF7-S Revision 2.0
    OCZ PC-3200 Platinum 2x512MB @ 426Mhz
    ATI Radeon X850XT
    WD 60GB | WD 40GB | WD 160GB SATA
    Antec Plusview 1000AMG | Thermaltake PurePower 420W Active PFC
    Windows XP Pro SP2
    Creative Sound Blaster Audigy 2 ZS | Creative MegaWorks 550 THX
    Laptop 1: Dell XPS M1710 | T2500 | 2GB RAM | GeForce Go 7900 GTX | Hitachi 100GB 7200RPM
    Laptop 2: MacBook | T7400 | 1GB RAM | 120GB
    Detroit
    Yes, for over an hour.
    Old School OCer OS-Wiz's Avatar
    St. Louis, Mo, USA
    More than likely WinXP doesn't like something to do with how the HD is configured. Check cabling, jumpers, etc. Does the BIOS correctly id the HD?
    Detroit
    Yes, the bios does detect it correcty. I just noticed that it is setup as Secondary-Master. I'll switch it to primary and see what happens.
    Detroit
    Nope, didnt help. I wonder what it could be...
    St. Louis, Mo, USA
    OK, tell us all the devices on each IDE port and how they're cabled and jumpered. A typical setup would look something like this:
    Primary, IDE1 = HD1 (boot drive) jumpered as Master, on end of cable, DVD jumpered as Slave, on middle connector of cable.
    Secondary, IDE2 = HD2 jumpered as Master, on end of cable, CDRW jumpered as Slave, on middle connector
    Detroit
    Primary = Hard Drive - jumpered as master - on middle of cable(changed to end)
    Secondary = CDRom - jumpered as master- on end of cable
    I pulled out all cards except for video and one memory stick. IT NOW WORKS! After installation completes I will put everything back in and pray to god it still works. Thanks
    St. Louis, Mo, USA
    Woohoo, good deal.
    Sushi dmann304's Avatar
    Jan 2004
    Chicago
    I think i could be your IDE drivers. If your using an onboard Promise comtroller i would switch to the standard IDE and leave it by itself and CD on secondary IDE. I had this problem a year or 2 ago and i kicked it real hard and it worked fine but i trashed gods name that day so probably got back at me for it. Lol try what i said and good luck.
