Sorry for the newb-ish question, but where is a good place to learn (in the quickest way possible) about the different AMD socket types, the processor groups that correspond with them, and the memory bandwidths that each group has?
I've built, cooled, and overclocked lots of intel systems and know a lot about them, but I don't know much about AMD motherboards, the chips that fit them, and the right memory type (PC2700 for instance) to buy. It seems like there are a whole lot more current classes of AMD chips and motherboards still in production than intels. I'd to know more so I can buy components and overclock them with confidence. thanks.
"There is something to be learned from a rainstorm. When meeting with a sudden shower, you try not to get wet and run quickly along the road. But doing such things as passing under the eaves of houses, you still get wet. When you are resolved from the beginning, you will not be perplexed, though you still get the same soaking. This understanding extends to everything."
Athlon XPs uses socket 462, Athlon 64 uses socket 754 and Athlon 64 FX51 uses socket 940 but it will be replaced by socket 939 for the FX53.
The memory bandwidth depends on the FSB the CPU is running at.
Palomino and Thoroughbred Athlon XPs runs at 133Mhz which gives about 2GB/s.
I don't know the bartons that runs at 166Mhz but the 400Mhz FSB barton (XP3200+) gives about 3GB/s.
I'd recommend going with PC3200 and up to ensure better OC. You will find the best timings in PC3200 or PC3500 sticks. Don't go with PC4000 sticks because of the loose timing they offer. The extra bandwidth makes up for the loose timing but that means you'll have to go quite high in FSB.
XELA!
Athlon XP2400+ @ 2343Mhz (11x213)
SLK 947U w/92mm Tornado w/Nexus 205
Abit NF7-S Revision 2.0
OCZ PC-3200 Platinum 2x512MB @ 426Mhz
ATI Radeon X850XT
WD 60GB | WD 40GB | WD 160GB SATA
Antec Plusview 1000AMG | Thermaltake PurePower 420W Active PFC
Windows XP Pro SP2
Creative Sound Blaster Audigy 2 ZS | Creative MegaWorks 550 THX
Coltrane,
Sit back and take a good long look at this site, Amdboard This covers the full gamut of boards, chipsets, ram, power supplies and everything related to your question.
Laterz,
dafanman
Gigabyte 7n400pro HARDM3NU FINAL Bios
Dual Boot XP/ME
xp1700axoa dut3c juhhb0302xpmw
11x200=2205.
Albatron Ti4200p 128mb
WD120gb, WD40gb
LiteOn 52x burner
Pioneer 10x dvd
(2) corsair 3200 xms 256@ 11-2-2-2.5
coolermaster hhc-001 heat pipe
650watts of psu 400for sys/ 250 for fans
19" Komodo monitor
Altec Lansing 5.1 speakers
Leadtek tv2000xp tv/fm radio card
Average load temp 52c/37c W/Dryer Hose Mod
still does matter....that mod tends not to work with most nforce2 boards, and since we all want to overclock with an nforce2 board....well...we're still kinda stuck.
- 2xRaptor 150GB RAID-0
