Help with Arctic Silver 5 Thermal Paste
Results 1 to 8 of 8
Thread: Help with Arctic Silver 5 Thermal Paste
    Reef Shark eysikal's Avatar
    Dec 2003
    Lancaster, CA
    Ok guys,
    I just ordered some new stuff for my system. I'm putting in some new lighting and an Arctic VGA Silencer.
    Here's what I need help with:
    I also ordered some Artic Silver 5 to make sure I get the best heat transfer from GPU to VGA Silencer. I am also planning to clean up the old stuff (Arctic Silver Ceramique) off my CPU and replace it with the Arctic Silver 5.
    I need some help (a guide maybe) on how to completely remove the thermal paste that is on my GPU, CPU, and heatsinks, as well as a guide for the best way in applying it.
    I followed Artic Silver's instructions when I applied the Ceramique, but I have noticed that some ppl are spreading it out over the CPU core in a thin sheet. How do I do that, and is it the best way?
    Thanks a lot guys...
    AMD Athlon Barton 2500+(locked)@ 3200+
    Abit NF7-S v 2.0
    2 x 256MB Mushkin Blk Lvl 2
    WD Raptor 36.7GB
    WD 80GB 7200 RPM 8MB cache
    ATi 9800 Pro @ 9800XT Speeds
    NEC MultiSync LCD 1980FXi 19in
    Great White Shark thrawn86's Avatar
    Jan 2003
    Auburn Univ.
    to remove the junk from your HS, just scrape it off with a razore blade, then wipe off the rest with a clean, lint free cloth and some high concentration isopropyl alcohol (rubbing alcohol).
    As for applying the paste, its my personal preference to spread it out in a thin layer, to make sure the entire core is covered. it doesn't matter so much if you put too much paste, because up to a certain point the mounting pressure of the HS will spread it out evenly anyway.
    AM2 Windsor 2.4ghz -> Asus M2N-E/ 2048mb G.Skill ddr2800 -> Sapphire x1800xt
    A2 Plat eX -->Canare Cables/Pimeta --> AudioTechnica ATH-A500 & Ety ER-6
    Infinity Primus 150 w/ Datyon 10" sub
    _____________________________
    Join the Sharky Folding@Home Team!
    Sharky's Extreme 3dmark Team
    Dec 2003
    Lancaster, CA
    Does it really make a difference what % alcohol you use? I can't seem to find anything higher than the typical %70.
    Also, I had to reapply my thermal paste once and the temp went up 2. I think it might have been because I used a little more than the previous time.
    I am looking to get the best temps by completely removing all traces of the previous paste and applying the Arctic Silver 5 in the best way possible.
    Abit NF7-S v 2.0
    WD Raptor 36.7GB
    Thread Killer Delphi00's Avatar
    Jun 2003
    Bay Area, CA
    the higher the % the faster the stuff evaporates leaving less traces behind...
    and i think your temps went up after you re-applied because it wouldn't not have "melted-in" (settled into the cracks) yet, but after a while, your temps should go down...
    Rig:
    P4 2.4C @ 3.0Ghz | Abit IC7 | Thermalright SLK 947U + Enermax 90mm | Scythe Ultra Kaze 120mm | Corsair 3GB | PowerColor HD3850 AGP | Antec SLK3700AMB | Enermax Whisper II 535W | Hercules Fortissimo III 7.1 | Samsung 931B | Logitech Z-2300 | WinXP Pro
    Jan 2003
    Auburn Univ.
    70% is fine, its all I can find at my grocery store.
    And AS5 takes about 200 hours of running time to "burn in", or completely settle into all the cracks and grooves of the heatsink. temps can drop anywhere from 2-5 C during this time, in my experience.
    Dec 2003
    Lancaster, CA
    Originally posted by thrawn86
    As for applying the paste, its my personal preference to spread it out in a thin layer, to make sure the entire core is covered.[/B]
    What is the best method for getting a clean, thin, even spread?
    Abit NF7-S v 2.0
    WD Raptor 36.7GB
    Jan 2003
    Auburn Univ.
    i like to use the single razor blades that you can buy in packs at home depot. In a pinch though you can use anything small and flat. ie: a credit card.
    Dec 2003
    Lancaster, CA
    ok, I will do that then...
    Thanks
    Abit NF7-S v 2.0
    WD Raptor 36.7GB
