Results 1 to 12 of 12
    Texan Dragon Moderator Galen of Edgewood's Avatar
    Ft Irwin, CA
    Exclamation Tutorials and Other Useful Programming Links
    I don't know why I never suggested or did this before.... What I want here is a compilation of good programming tutorials and, in general, a reference section for any and/or all programming languages, centralized in a single thread. Sound good to y'all?
    Book suggestions are suitable for this thread as well. Oh yeah, SPAM is bad, m'kay? This is not a free post thread, so don't treat it as such.
    Database is now open for entries here.
    Dragon of the OC Crusaders
    Break the rules and you're snack food for this dragon...
    cprogramming.com
    Ive saw this posted on the forums before to learn c++. Pretty good site.
    Ft Irwin, CA
    There is always the starting point for Java:
    http://java.sun.com/
    And a good one for Perl
    http://www.perl.org
    Expensive Sushi cjohnson's Avatar
    Oct 2002
    North Carolina
    For information on function pointers in C: function-pointer.org
    A nice book on OCaml is free online: O'Reilly's Developing Applications with Objective Caml
    A really weird introduction to Ruby is Why's Poignant Guide to Ruby
    The first edition of Programming Ruby is available online as well.
    A decent introduction to regular expressions is on regular-expressions.info.
    For PHP, nothing's better than the manual.
    If you want to learn about Scheme (or computer programming in general, really), the ever popular "Structure and Interpretation of Computer Programs" from MIT is available online (http://mitpress.mit.edu/sicp/full-text/book/book.html) and has accompanying video lectures!
    Also of use to lots of other things is MIT's OpenCourseWare.
    <wik> /bin/finger that girl in the back row of machines
    Sep 2001
    Lisbon, Portugal
    Links:
    http://www.planet-source-code.com/
    http://www.windevnet.com/
    http://www.programming123.com/topics/visual_c++.html
    http://javascript.about.com/cs/windowtutorials/
    http://www.symbian.com/developer/downloads/tools.html
    http://www.daniweb.com/techtalkforums/forum8.html
    http://www.brainbench.com/xml/bb/homepage.xml
    http://devcentral.iticentral.com/art...t1/default.php
    http://www.codersource.net/cpp_copy_constructors.html
    http://www.geocities.com/contactgirish/homepage.html (MFC and stuff)
    http://www.softlookup.com/tutorial/vc++/vcu35fi.asp
    http://www.freeprogrammingresources.com/visualcpp.html
    http://pdf.coreservlets.com/
    http://www.programming-x.com/program...ing-links.html
    http://www.fawcette.com/vsm/2004_01/...oks/page2.aspx
    http://www.masterasap.com:8080/lesso...5/lesson.jsp?2
    http://www.apl.jhu.edu/~hall/java/Servlet-Tutorial/
    http://www.webdevelopersnotes.com/tu...ascript/9.php3
    http://www.xsellnewmedia.com/js_workshop/events.htm
    http://www.daysite.net/programming/jsp.htm
    http://www.mindview.net/
    There are more sites that I use or have used, but these should suffice.
    As for books, some of the ones I have are:
    - Java
    Big Java
    Java Bible
    Professional Java Programming
    Sun's Java 2EE Tutorial 2nd Edition
    Java in a Nutshell
    The Art of Java
    Effective Java
    - MFC
    MFC Bible
    MFC Black Book
    - C++ / VC++
    Big C++
    The C++ Programming Language
    VC++ .Net Bible
    C++ Primer
    C++ Unleashed
    Effective C++
    Accelerated C++
    Sams Teach Yourself Database Programming with VC++6
    Sams Teach Yourself VC++6 in 21 Days
    - Javascript
    Javascript Bible
    - C#
    Professional C#
    Mastering Visual C#
    Mastering ASP .Net with Visual C#
    C# Complete
    - XML Web Services
    XML Unleashed
    - ASP .Net
    Asp .Net for Dummies ( )
    And then I have tens of other books in e-format, but I always liked paper books more.
    Catfish webraycer's Avatar
    Midlothian, VA, USA
    www.w3schools.com has great references and tutorials for HTML, CSS, Javascript, PHP, ... etc. Pretty much everything web related.
    Sleeps with the Fishes Alec§taar's Avatar
    Apr 2005
    A Discrete Point in the Space-Time Continuum
    FOR BORLAND DELPHI CODERS:
    Torry's Delphi Pages -
    http://www.torry.net/
    Delphi SuperPage -
    http://delphi.icm.edu.pl/
    Borland Community -
    http://cc.borland.com/
    * They're pretty much all a Delphi/Object Pascal person needs for developing true, stand-alone, FAST executeable files for Linux using Kylix, or Win32/.NET apps using Delphi!
    APK
    Apr 2001
    San Jose, CA
    Safari Bookshelf
    One of the best references period... It has most if not all of Oreilly's books up for read and its free if you are in a university.
    http://safari.oreilly.com/
    ~The black wind howls..~
    My c0mp:
    -AMD Athlon XP1800
    -SK6 w/ Delta 60mm
    -Shuttle AK31 (kt266a)
    -512mb CRUCIAL PC2100
    -ATi Radeon8500 retail
    -40 gig IBM 60GXP
    -Plextor 16/10/40A
    -Pioneer 106S DVD-rom
    -Game Theater XP
    -Sony MDR-V6
    Jun 2011
    the darkside of the internet
    what operating system can i use to write and view the programs?
    Aug 2004
    Urbana, IL
    Quote Originally Posted by deathtech20 View Post
    It all depends. Most programming is done through Windows, but all the main OS's can write programs. As long as it has a text editor. To compile, you need a compatible operating system. I would recommend Windows. You need to install the programming library for the language you want to use and then I would recommend getting a good programming environment such as Eclispe. These give you realtime code debugging and suggestions. Some even come with templates and tutorials.
    If you are fresh, it will probably take a day or so just to set your computer up correctly to program.
    Main Rig: Watercooled
    EVGA 680GTX | Intel 320 SSD + Crucial M4 256GB | Corsair 750TX | Corsair 800D
    Hackintosh Workstation: Aircooled
    EVGA 640 GT | WD RE4 500GB | PCP&C 600W | G5 Case
    Toys:
    iPhone 4 | iPad 3 | PS3 | Xbox 360 | PSP-3000 | Supermicro based NAS | Steelcase LEAP!
    Currently playing: Guild Wars 2
    Last Game Beaten: Walking Dead EP1
    Quote Originally Posted by Chronus View Post
    Links:
    - Java
    Big Java
    Java Bible
    Java in a Nutshell
    The Art of Java
    Effective Java
    - MFC
    MFC Bible
    MFC Black Book
    - C++ / VC++
    Big C++
    VC++ .Net Bible
    C++ Primer
    C++ Unleashed
    Effective C++
    Accelerated C++
    - Javascript
    Javascript Bible
    - C#
    Professional C#
    Mastering Visual C#
    C# Complete
    - XML Web Services
    XML Unleashed
    - ASP .Net
    thanx
    y8 | Miniclip | y3 | friv | ben10 | y8 | kizi | y8 | y3 | y8 | pogo
