Then you may want to try other burnware to see where your problems lie.
I could be wrong but it sounds as if it's related to Nero 6 . Burnatonce is freeware burnware that you can try.
i used cheetah CD. It seems that a 3rd party works.
Its unclear if Nero sucks right now, or cause this is a backup copy from a friend for the Nero. In trade for my 5.0 and a cd burner..no illegal copies you @sshole Riaa people..
Anyway, it seems that things are Not going to the right default. Theres no languages in Nero, and opening it up WILL CRASH the program.
I only need english anyway, and this Burn At once I didnt know how to use.
I have only ONE dvd burner. How can i make that the source and the copy drive? It seems to default automatically on the old version of Nero, but for some reason it doesnt anymore for these other programs/versions.
I've never used Burnatonce Buster, so I can't help ya out there. But if you are having problems with it, there are other free burner options out there to try out as well.
I've heard good things about all these free burners, but I've been using nothing but Nero forever so I don't have any guides or hints for them...hopefully you can get one of them to work you
Sharky Extreme 3DMark Team
i5-750 @ 3.15Ghz w/ Cooler Master Hyper 212+||Gigabyte GA-P55-USB3||4x2GB Corsair XMS3||Gigabyte HD 5850||Corsair 650HX PSU||Dell 2405||Win7 HP
Jexx11 on Xbox360 & Steam
gar on Xfire Currently Playing: 360: CoD MW 2, PC: WoW, Borderlands, Call of Duty: Black Ops
Originally posted by Buster Sword Yeah the cd burnt with Cheetah, but then its only for CDS and ..expires soon
How do you work this burnatonce? i hit copy on the fly and it doesnt work
If you only have one optical drive then you cannot use the copy on the fly option.
Select Read/Copy>>>>Read to Image to read the disc and create an image on your hard drive. Once the image is written to the drive you will automatically be prompted to load the image to be written. At this point you would insert a blank disc.
If you prefer to manually load the image, then select File>>>>Load New Image.
