Results 1 to 3 of 3
    Catfish Data3's Avatar
    Jun 2003
    Ft Worth, TX
    win 98se ie problem
    A friend has an old computer with 98se and he lives in the country and can't get dsl or cable internet, has dialup. I use ie on my computer so when I go to his house and use the internet I always minimize his isp and use ie. I was just over there and when I pulled up ie it just put the bar across the top that says Microsoft Internet Explorer and nothing else. I tried going into add/remove programs and did a repair. I also went into Microsofts web sight and downloaded the latest version but it still did the same thing. Does anyone know what else I could try?
    Thanks in advance.
    Mobo--Gigabyte GA-MA69G-S3H
    CPU---AMD 2.8 GHz
    Mem---1GB DDR2
    HDD---Western Digital 160gb (XPpro)
    Lite-On CD,DVD rom
    Lite-On CDRW,DVDRW
    Sound-SB Audigy 2
    BozoKiller
    Oct 2003
    Zoso
    possible the window is sized for title bar only? try maximizing window - or drag the chevrons, grab a corner with the mouse.
    start > run Regedit
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
    delete "Window_Placement"
    Delete the Electoral College - Support
    www.NationalPopularVote.com
    "The world according to DRM Bozos"
    I am a consumer, I'll buy anything
    I am a sheep, I am cattle, I follow the herd
    I am ignorant, a dumbass, and I am a bozo...
    I am the epitome of the 'rank and file'
    I am your next door neighbor
    I am 95% of American Consumers
    I will consume you
    • If the light in your head hasn't come on yet,
      I suggest you go get a new bulb!
    Jun 2003
    Ft Worth, TX
    thanks, I will give that a shot.
    CPU---AMD 2.8 GHz
    Mem---1GB DDR2
    Lite-On CD,DVD rom
    Lite-On CDRW,DVDRW
    Sound-SB Audigy 2
