Blurry Desktop Icons on Widescreen Monitor
Results 1 to 7 of 7
Thread: Blurry Desktop Icons on Widescreen Monitor
    Jun 2005
    I have a 1920 x 1200 widescreen LCD on my Dell Inspiron 9300. At this resolution, the icons for Windows XP and various other programs become blurry because they were not designed accordingly. Is there a tweak I could perform to scale down the size of the icons so there wouldn't be any "jaggies?"
    Mako Shark rhettro's Avatar
    Apr 2001
    Black Mesa, Arizona
    I not sure, but it sounds like you aren't running Windows at 1920x1200 resolution. Check your display properties to verify that you are.
    GSD on patrol kenrippy's Avatar
    Orange Co. CA
    also try turning off "clear type" and see if that helps.
    Q6600 "G0" @ 3.6ghz (400x9) - tuniq tower - IP35 Pro - 4x1gb ballistix ddr800 - Thermaltake W0128RU 650w - 2x74gb raptors raid-0 (OS drive)
    heat ebay
    Jun 2005
    Positive I'm running it at that resolution.
    Here's an example of what I mean. Imageshack compressed the screenshot down a bit, but on the "turn off computer" menu you can still see jagged edges on the buttons.
    Mako Shark PriMaTe's Avatar
    on one of my lcd's there is a sharpness level you can change, from 1-3. Depending on what setting it's on the picture can look a little fuzzy and off, or be nice and clear, mayeb yours has a setting like that? It is a dvi lcd too.
    Corsair 550vx
    GIGABYTE GA-EP45-UD3L
    C2D e6750 @ 2.66
    2 gig ram
    Asus Radeon 4850
    Audigy 2
    Defiant Shark Johnmcl7's Avatar
    Apr 2003
    Edinburgh, Scotland
    Right click your desktop and go to properties, then choose the last tab (which shows the resolution) and click advanced. In the first tab 'general' you'll see a DPI setting, change this down to normal (96 dpi) and you'll have everything 'proper', no jagged upscaling. To compensate for the ultra high resolution, Dell always seem to increase the DPI (been the same on my 8600/9300/XPS 2) which I find annoying as it looks crap, so much better when you reduce the DPI to normal.
    John
    Alienware Aurora R4 (i7 3930K), Dell Studio XPS (i7 940), XPS M1330, Studio XPS 1640 (RGB LED 1080p), XPS M1730, Sony UX1XN, TX1HP, Lenovo X200
    Jun 2005
    Thanks John, problem solved.
