Results 1 to 7 of 7
    Hammerhead Shark phelan1777's Avatar
    Mar 2003
    Phila, Pa
    Fan controller vs non adjustable fans.
    Okay, so most likely a dumb question, but, the fans that are not adjustable, if connected to a controller, then I can control RPMs?????
    I would like to think that I could, but I wanted to ask, if someone knows.
    Thanks,
    Phelan1777
    QX6700 @ 2.9, 3.2, 3.4, not quite 3.7
    Brd_122-CK-NF68-A1_EVGA
    Opt_2X_Px-716SA_Plextor
    Psu_SST_75ZF_SilverStone
    Os_Xs_Os_&_Xp_Prp_XSOS
    Box_Stacker_810_Cooler_Master
    Ram_Crucial_Ballistix_PC28000
    Vga_eVGA_8800GTS_ SLI_EVGA
    Hdd_320GB_72K.10_74GB_Sata_Seagate/WD
    Rd-30/Pa120.3/LiTtLe RiVeR G5!/2X MCW60s/MCW30
    (My work in progress)
    Stacker SLACKER Thread
    I reject your reality and substitute it with my own. Adam- Myth Busters
    Tiger Shark UghMAS's Avatar
    Feb 2004
    123 Fake St. Endicott, NY
    yes.
    Main Rig Undergoing surgery
    Mar 2003
    Phila, Pa
    Thanks for the fast reponse U.
    Feb 2004
    Quote Originally Posted by phelan1777
    just to elaborate, the fan controller just varies the voltage that goes through the fan. and Power=VoltsxAmps so if your lowering the voltage its going to be putting out less power therefore spinning slower.
    Mar 2003
    Phila, Pa
    so any recommentdations for a 4+ fan controller?
    I liked a Zalman one I saw.
    Catfish xcessiv's Avatar
    Dec 2005
    Diamond Bar
    id say go for it, i got a vantec one b4 and 2 of the 4 controls blew up when the fan had an issue. i dont know if im the only one but ya.. that sucked. the other 2 still work
    and yes... they BLEW up. that bigger sized square resistor type piece exploded and i found fragments at the bottom of my case. threw out those fans SO fast.
    :: Intel E6750 w/ Zalman 9700 :: XFX 780i SLI :: eVGA 8800GT Superclocked :: AData 2 x 2GB DDR2 800mhz ::
    :: NZXT Lexa (Piano Black) :: 3x 120mm & 3x 80mm
    Got Tired of: Bioshock / Crysis
    Loving: GRID and DMC4
    Havent had time for:
    Finishing Spore (trying to kill Grok)
    HEATWARE FEEDBACK
    Feb 2004
    my favorite:
    http://svc.com/bus-55-sl-24.html
    http://svc.com/bus-54-bk-24.html
    leds are a little bright but it is a top basic 4 fan controller. I LOVE it, i wish it was 9.99 back when i bought mine.
