Rewiring Headphone plugs. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Rewiring Headphone plugs.
  1. #16
    By the Power of Greyskull Colossus's Avatar
    Jul 2002
    Boston, MA
    I know, but it can smell like copper, taste like copper, but still not be copper
    The cables I had to repair (a few in my years) all had either multi colors on the strands of wire or they were copper with still the coating.
    Its not the standard stripping a wire by taking the rubber insulation off But if your headphone cable is not like that, then great it would be easier to solder.
    Intel I9 14900K|ASUS - MAXIMUS Z790 HERO|ASUS GTX 1080 Ti|64GB G.Skill|(3) Samsung 990 Pro 2TB NVME |Custom water cooling||Alienware AW3423DW 34" OLED
    288TB Plex server (UNRAID)
    (18) WD 16TB Red
  2. #17
    Senor Sausage
    Dec 2003
    Singapore
    Quote Originally Posted by Colossus
    I'll check.
    Edit: They aren't, one of my channels was packed next to the ground wire.
    Xbox Live Gamertag: Weistber
    Gaming Rig Status: Up
    | i5-2500 | MSI GTX560 | 2x2GB Corsair ValueRam
    Games I'm playing: Witcher 2 (PC), RAGE(PC), Fallout: New Vegas (PC), Gears Of War 3 (X360)
  3. #18
    Hammerhead Shark Candyman's Avatar
    Aug 2002
    Redwood City, CA
    Yeah, the wire lacquer stuff they use is annoying. Another way to get rid of it is to burn it off with a really hot soldering iron (or propane torch ).
    Core 2 Duo 6750
    Antec P182
    Abit IP35 Pro
    4 GB DDR2 800 RAM
    Asus Xonar D2
    Panasonic SA-XR55 / Audio Technica ATH-A900
  4. #19
    Jul 2002
    Boston, MA
    But if you burn to long with a propane torch, the rubber insulation wouldnt be good anymore or burned up If you got a bit careless with it..
    I never tried using a torch, maybe next time when I repair a headset I will give that method a try
    (18) WD 16TB Red
  5. #20
    Aug 2002
    Redwood City, CA
    That part was actually a joke. I just like burning things with propane torches.
    Core 2 Duo 6750
    Antec P182
    Abit IP35 Pro
    4 GB DDR2 800 RAM
    Asus Xonar D2
  6. #21
    Jul 2002
    Boston, MA
    Doh!
    So what method would you use to remove the lacquer from the cable?
    (18) WD 16TB Red
  7. #22
    Aug 2002
    Redwood City, CA
    Doh!
    Soldering iron usually does the trick. Helps if you have a temp-adjustable one so that you can turn it all the way up.
    Core 2 Duo 6750
    Antec P182
    Abit IP35 Pro
    4 GB DDR2 800 RAM
    Asus Xonar D2
  8. #23
    Senor Sausage
    Dec 2003
    Singapore
    Thanks I'll keep that in mind.
    Have one, a little weak though.
  9. #24
    Jul 2002
    Boston, MA
    I used a 45w iron and it was not able to burn it off.. I can get my good old weller iron gun and get even hotter
    (18) WD 16TB Red
  10. #25
    Senor Sausage
    Dec 2003
    Singapore
    Damn, mine is only 40w.
  11. #26
    Great White Shark thrawn86's Avatar
    Jan 2003
    Auburn Univ.
    "Yes, I understand. I am taking engineering."
    hey you asked, just trying to help. circuits is a first year course here
    AM2 Windsor 2.4ghz -> Asus M2N-E/ 2048mb G.Skill ddr2800 -> Sapphire x1800xt
    A2 Plat eX -->Canare Cables/Pimeta --> AudioTechnica ATH-A500 & Ety ER-6
    Infinity Primus 150 w/ Datyon 10" sub
    _____________________________
    Join the Sharky Folding@Home Team!
    Sharky's Extreme 3dmark Team
  12. #27
    Senor Sausage
    Dec 2003
    Singapore
    Quote Originally Posted by thrawn86
    I did that to save you the trouble of further explaining. I appreciate your help.
  13. #28
    Tiger Shark shasha's Avatar
    Oct 2001
    Germany
    The best way to get the laquer off in my experience is to use flux. I wouldn't bother with reusing that old jack either and don't try to solder the wires together, just get a new jack from somewhere like radio shack for $2, cut the cord at the bad spot and solder it to the new jack. It will look like new and if you are that rough on them you can easily reuse that jack the next time you hose it.
    WinXP Pro SP2 ABIT IC7 Intel P4 3.0E 1024M Corsair PC3200 DCDDR ATI AIW Radeon 9800Pro (400/355) 2 Samsung SV1204H 120G HDs AudioTrak Prodigy 7.1 3Com NIC LG GSA-4163B DVD burner LG GCC-4480B DVD/CD-RW burner Elan Vital Greeneger SSM 500W Cooled by Zalman Altec Lansing MX-5021
