Dead Toshiba Motherboard
Results 1 to 8 of 8
Thread: Dead Toshiba Motherboard
    Expensive Sushi bronyraur's Avatar
    Jun 2006
    Exclamation Dead Toshiba Motherboard
    I am looking for a motherboard for a Toshiba Satellite M35X-S309. On the motherboard below and to the right of the chipset it says:
    EAL20 LA-2461 Rev:2.0
    Made In CHINA
    2004-11-17
    Vendor: GCE
    It has a 1.4ghz intel centrino.
    I need to identify so I can purchase a new one.
    AMD64 4000+
    DFI Lanparty NF-4 Ultra
    1gb Corsair XMS PC3200
    Evga Geforce 6600 256mb
    80gb WD SATA x2 160gb Seagate SATA Archive drive
    17inch LCD Monitor
    XP Pro
    MacBook 13inch
    1.83 CoreDuo
    1gb DDR2 667
    80gb SATA
    OS X 10.4.8
    xfire: bronyraur
    Great White Shark hongsc's Avatar
    Apr 2002
    Los Angeles
    Quote Originally Posted by bronyraur
    Made In CHINA
    2004-11-17
    Vendor: GCE
    Have you tried Toshiba's website and do a search under parts? You can also try notebookforums.com for help.
    Macbook Pro: Dual Boot: OSX Leopard/Vista Home Premium|2.2GHz Intel Core 2 Duo|4GB RAM|128MB 8600GT|120GB HDD|Double-layer SuperDrive|1TB Seagate|Logitech VX Nano|Apple Al BT keyboard|ATH-A500|8GB iPhone|
    Jun 2006
    toshiba no help. I posted in notebookforum.com maybe they can help me. Thank you.
    AMD64 4000+
    17inch LCD Monitor
    XP Pro
    MacBook 13inch
    1.83 CoreDuo
    1gb DDR2 667
    80gb SATA
    OS X 10.4.8
    xfire: bronyraur
    Jun 2006
    AMD64 4000+
    17inch LCD Monitor
    XP Pro
    MacBook 13inch
    1.83 CoreDuo
    1gb DDR2 667
    80gb SATA
    OS X 10.4.8
    xfire: bronyraur
    Mako Shark Chuck232's Avatar
    Jul 2002
    WA
    Wow, pricey...
    • -|C2D E6600|-|ASUS P5W DH|-|OCZ 2x1GB PC2-6400 Platinum XTC|-|Scythe Infinity|-|Seagate 7200.10 320GB|-|eVGA 8800GT 512MB|-|BenQ DW1655|-|Antec P180B|-|OCZ GameXStream 600W|-|LG L204WT|-
    • -|Dell XPS M1330|-|Core 2 Duo T7100|-|2x1GB DDR2 RAM|-|Hitachi 120GB 5400RPM|-|NVIDIA GeForce 8400M GS 128MB GDDR3|-|Intel 3945a/b/g|-|8X slot load DVD+-RW|-
    • Sharky Extreme 3DMark Team
    • site
    Apr 2002
    Los Angeles
    Quote Originally Posted by Chuck232
    Wow, pricey...
    Yeah I had a similar problem and I was quoted $300 to $600 depending on the model. To OP at $400 I would rather buy a new laptop like a Core Duo from Dell, HP etc. and sell the Toshiba for spare parts. Also installation would cost you an extra $75 to $150 if you pay someone to do it. If you decide to do it yourself it can be a pain dealing with all the screws etc when taking it apart. There have been recent deals with HP, Dell etc between $400 to $800 for Core Duo laptops.
    Mar 2008
    about the M35X series...
    i can fix any M35X motherboard. i charge 60 bucks. call me up 805-732-3996
    Dan
    Mako Shark wh666-666's Avatar
    Jul 2006
    In a red kennel
    If it cant be fixed though, consider ebay for new/used parts far cheaper than any website ....
    Over time ive built up a few contacts through ebay that i deal with externally now ....
