Results 1 to 5 of 5
    Jul 2002
    Caerphilly, Wales
    Question Radeon drivers/2D-performance issues - mutiple cards
    I have a quin-head rig:
    Radeon X1900XT 256MB PCI-E (2x Dual Link DVI)
    Radeon 9250 128MB PCI (1x DVI, 1xHD15)
    Radeon IGP1150 (onboard X300, 32MB shared, 1xHD15)
    The rig is a Sempron 3000+ with 2GB Corsair XMS3200 (4x512) on a Giga-byte mobo.
    I only use all heads when in 2D, in 3D I only use the primary screen on the X1900XT.
    The screens on the X1900XT are always near-perfect ... the screen on the IGP1150 is adequate, but the screens on the 9250 are very laggy in 2D -- e.g. if I drag a window around I see it redraw approx twice a second, whereas on the X1900XT the movement is perfectly smooth.
    I've checked ATI's (or should I say AMD's?) site for driver updates and realised that the 9250 is no longer fully supported in latest Catalysts and that older Catalysts should be used for such BUT I can't have both and thus need some other way of resolving the performance issue which I believe to be driver related, yet I need newer drivers to ensure that the primary screens display well, especially if playing a game.
    Suggestions please
    Q9450 with Skythe Zepang HSF :: Abit mobo :: 4GB OCZ Reaper with heat pipes :: Dual Radeon 9370s :: Akasa 850W gaming edition PSU :: 6 x Seagate 7200.11 750GB RAID 0+1 Creative X-Fi xtreme gamer :: Cambridge Soundworks Gigaworks 750 7.1 speakers :: Logitech MX1000, Natural Keyb, TacticalBoard & NuLooq :: Dell 3008 30" TFT :: 2 x 22" TFTs
    Catfish Mach5Motorsport's Avatar
    Feb 2006
    1hr from Silicon Valley, CA 15 min from Laguna Seca, CA
    time to bid adeu to the 9250 and use a card that is still supported. problem solved.
    Mach5Motorsport "Dieter"
    AMD 64 3000+ Socket 754/AGP (With Pride!)
    6800GS
    HP Pavillion dv8000t (Duo Core T2250 with Nvidia Go7600)
    Speech Instructor
    Hammerhead Shark Spank_Me_Hard's Avatar
    Feb 2004
    Ventura. California
    Careful with using "2D"...
    Someone may come around and get angry saying that "2D" doesn't exist...
    (or something to that effect)
    Quote Originally Posted by Concerned Citizen View Post
    We should nuke the United States.
    i7-930 CPU w. Scythe Mugen2, Intel DX58SO mobo, WD Raptor 600GB 10K RPM HDD, 8GB PC12800 RAM, nVidia GTX285 2GB w. Artic Cooling Extreme, Antec P182SE case, Enermax MODU87+ 850W PSU, Vista 64 bit business, Xeno 128MB PCIe Killer NIC, Creative X-Fi Fatal1ty PCIe, Viewsonic 28" VX2835wm LCD
    Jul 2002
    Caerphilly, Wales
    Does anyone have anything constructive to say?
    There seem to be no newer cards available to replace the 9250 - PCI cards just ain't available to buy.
    Considering the issues are not when using OpenGL / Direct3D etc., but rather the primitive drawing of the Windows OS, then "2D" will suit fine.
    Feb 2006
    Quote Originally Posted by Bothware
    You need to look.
    Visiontek has a x1300 in PCI available now.
    BestBuy ref #VTK X1300256PCI $129.99
    CompUSA ref#VTK-X1300256PCI $129.99
    Diamond also makes a X1300 PCI as well.
    Amazon.com ref#X1300PCI256SB $109.99
    6800GS
    Speech Instructor
