Results 1 to 7 of 7
    Hammerhead Shark Gunslash's Avatar
    Sep 2001
    NYC
    8800GTS in a Shuttle SN25P
    Well it works...err worked.
    The Shuttle Powersupplies are really good, so I had no doubts that the 350W would power it. It fit a little tight, but it fit.
    Ran hot, but once I upped the fan speed a bit it was comfortably warm with a high 50s idle, and load in the 60s-low 70s...not bad for a small case.
    It all worked great, except:
    -the sticker on the 8800gts fan came off and got stuck in the fan, so that was a scare.
    -card died within 1 or 2 hours
    it didnt work in my system or any other ones, so the card's definitely dead
    bad thing is i'm on a military deployment so it'll take a few weeks for me to get a replacement from newegg
    performance wise it was good. Played Quake4 and Prey maxed out (1280x1024 monitor resolution's limited), 16x af, 16x aa, max shadows, etc...
    not a hitch anywhere. Medieval 2 didn't like max details though, was a bit choppy, so I settled for semi maxed.
    So right now I'm back to using my 7900GT which surprisingly handles all the games almost as well at my resolution. Quake 4 at max detail (4x AA, 16x AF) looks 95% as good and is just as smooth...same with Prey. Medieval 2 runs great too with 4x AA, low shadows, everything else maxed.
    Though to make up for the speed difference, I finally had the balls to O/C my 7900GT...and man O/C is good with this one. Bumped GPU from 500 to 515( ok I guess), and memory 750 to 900( ) and life is good.
    well I still can't wait for my new 8800GTS to come back, but unfortunately it'll probly get here after all the holidays are over. But oh well, I've found new life in my 7900GT which was still plenty fast to begin with, but even better now.
    I7 920 (C0)@3.2ghz
    Asus P6T
    SLI MSI GTX465 Twin Frozr II GE unlocked to GTX470
    6GB Ram
    Intel SSD
    Raptor-150GB
    Vista 64
    Sharky Extreme 3DMark Team
    Super Villain Moderator Un4given's Avatar
    That really blows dude. I hope the next one works, and that the reason for the premature death was just one of those things, and not due to the PSU not being able to consistenly supply the amount of clean power needed to power such a beast.
    Intel i7 3.2GHz @ 3.93GHz
    Houston, we have lift off!
    I'm just amazed that it fit in the Shuttle SFF!!
    I hope you get it replaced soon...
    8 GB Corsair Vengeance DDR3-1600|Antec TruePower Trio 550W
    MSI R6850 PE/OC (860/1100)|Catalyst 12.4|Acer 20"
    16 GB G.Skill Ares DDR3-1866|Corsair AX850
    Asus HD 7850|Catalyst 13.1|X-Fi XtremeMusic
    Klipsch ProMedia 2.1|Sennheiser HD-580
    Logitech WingMan RumblePad USB|Logitech G5
    Win 7 Home SP1|APC SmartUPS SUA1500
    Heatware & eBay | the Gamer Planet | XFire
    gran tiburón blanco ewitte's Avatar
    Jul 2002
    Houston, TX mostly. Lima, Peru partiallly.
    Now try a 8800XTX in a shuttle Thats one thing I don't like about SFF is the power supplies are so small.
    Mako Shark Skywize's Avatar
    PA, USA
    I hope "removing" the sticker on the fan didn't void the warranty
    A64 3700+ (San Diego)
    ABIT KN8 SLI
    2x512MB PC 3200 DDR
    BFG GTS 250 1 GB
    SB Audigy
    250gig Maxtor Maxline Plus II SATA HD
    Viewsonic VA1912wb
    Sep 2001
    NYC
    Quote Originally Posted by Skywize
    lol well it's actually the little evga sticker on the face of the fan itself that flew off. underneath it is a same size nvidia sticker lol. reference design to the bone it seems
    I7 920 (C0)@3.2ghz
    Asus P6T
    6GB Ram
    Intel SSD
    Raptor-150GB
    Vista 64
    ... Reign's Avatar
    Nov 2002
    Europe
    so what killed it in the end ? sticker stuck in fan and then the card bacame too hot ? or the sticker came off because because the card got too hot ?
    Intel QX6700 Tuniq Tower (3,30Ghz) |Intel D975XBX2 |4x 1GB OCZ Platinum XTC DDR2-6400
    Gigabyte 8800Ultra OC'd to (650/2200/1605)| X-fi XtremeGamer Fatal1ty Pro | Dell 2005 FPW
    Lian-Li v1000 plus| Silverstone ST56ZF 560W |WD Raptor 150GB |2x Seagate 7200.10 320GB
