Originally Posted by DJBeanPole17
Yea but the booster, accoriding to OCZ, is not compatible with my mobo
You could always volt-mod your mobo: http://www.xtremesystems.org/forums/...&highlight=a8v
TEAM AWESOME!
Yes, but I would have no idea how to begin to do that. And the dude's board got fried.
MakoSharkero
"FSB @ 216-217MHz"
if that is all you are shooting for, then you don't need the Vdimm booster module or Vdimm mod, your board delivers enough juice to run the ram @217 easy....
just what is it you want to do? it seems you are all over the place, i can tell you that running the HTT Async with the ram @217 whould be easy with that 185, should do it on stock volts to both the CPU and the ram...
maybe you should read this first, http://www.diy-street.com/forum/showthread.php?t=28049, read it a couple of times, then put what you learn into practice...
laterz
Tbird quotes:
"I am done with 3dmark."
AsRock 970 Extreme4,Vishera 8320 @4.6, Vertex 4 256GB SataIII SSD, 2xVelociraptor 600GB 10,000 spinner in raid 0 storage....16g Gskill DDR3 2133 @2292, ATI 6850, back on huge air (quiet)....HP Laptop redone OS (ie, no HP krud ), AMD Phenom II N620, 8gig DDR3 1333 ram, Sanddisk SataII 120GB SSD, Toshiba 500GB 7200 spinner...
