Results 1 to 15 of 15
    Ultra Great White Shark!! richardginn's Avatar
    Guru3d: Radeon HD 4850 2 GB GDDR3 review
    http://guru3d.com/article/radeon-hd-...gddr3-review/1
    I do not think we had a post up for a review of this video card.
    It actually beat a 512 meg card a couple of times.
    www.myeducational plan.com-come see my plan to fix the USA educational system. I hope this is sig legal. Major Site Design Update on July 18, 2006. On June 18, 2009 passed the 10,000 post mark. December 24, 2009: Major Theme change and more....
    Mr Zurkon is here to kill PointlesS's Avatar
    Polaris Galaxy
    if you crossfire these and run 32-bit windows then what happens to your available memory?
    Save ana...!!
    Lian Li PC-K7B | Intel i5 750 | 4GB A-Data 1600 | Gigabyte GA-P55-UD3R | XFX Radeon 5850 | 2-640GB WD Caviar Blue | X-fi Xtrememusic | Klipsch Promedia 5.1 Ultra | Dell U2311H | Antec Basiq Plus 550W | NEC 3550A | Win7 Ultimate x64
    and a whole lot of lovin..
    Nov 2007
    u get f'd
    Asus M4A79T
    AMD Phenom II X6 1055T
    2x1 GB Crucial ballistix DDR3
    32 GB SSD
    640 GB SATA II HDD
    Gigabyte 5850 OC
    Windows 7
    Quote Originally Posted by rimmerchant
    it's like choosing whether you want to be kicked in the left or right nut..
    Reef Shark Frraksurred's Avatar
    Nov 2003
    Iowa
    This would have been a decent idea on a factory OC'ed 4870 (that could take advantage of the crazy AA this size buffer would enable), but it seems kind of a waste on the 4850... especially since they had to lower the clock speed to utilize it.
    It is too bad they cannot figure out a way for Windows to recognize the memory buffer of both cards in a Crossfire / SLI setup. Then the 2g on the "X2" models would be perfect.
    Cosmos S|CM Slient Pro 1000|Evga E760 "Classified"|i7 960|6 Gb DomGT|128Gb Torqz SSD|2 x 1TB Caviar Black|5870 XXX Crossfire|9800GTX PhysX|X-Fi|Triple XHD3000 Eyefinity @ 7680x1600|Marantz-Axiom-Velodyne 7.1|64bit Win7
    pictures below
    +t+ FRRAKSURRED +t+
    Ps. 51:17b
    Mako Shark Nater's Avatar
    Dec 2005
    Crawfordsville Indiana
    That amount of frame buffer seems like a complete waste on a card that really doesn't have the horsepower for high-resolutions. I honestly can't see that the king of the hill R700 card will really use all of it's 2x1GB frame buffer. It might make some sense there however, since I believe that all textures must be stored in the memory of both GPUs since there is little in the way of communication between the two chips.
    Q6600 @ 3.6GHz (Tuniq Tower 120) - DFI Lanparty LT P35-T2R - 8GB Corsair DDR2-800 - eVGA GTX 275 SC - SoundBlaster X-Fi - Western Digital VelociRaptor 300GB - Seagate 7200.10 750GB (2) - Western Digital 1.5TB Green (2) - Western Digital 2TB Green - WINDy-Soldam MT-Pro 1700 - Antec Signature 850W- HP LP2475W (H-IPS) - Samsung 204B (TN) - Alienware Ozma 7 Headphones - Windows 7 Ultimate
    ... Reign's Avatar
    Nov 2002
    Europe
    it has no effect whatsoever. The differences are so small that would you get them by doing the test twice with the same card.
    Intel QX6700 Tuniq Tower (3,30Ghz) |Intel D975XBX2 |4x 1GB OCZ Platinum XTC DDR2-6400
    Gigabyte 8800Ultra OC'd to (650/2200/1605)| X-fi XtremeGamer Fatal1ty Pro | Dell 2005 FPW
    Lian-Li v1000 plus| Silverstone ST56ZF 560W |WD Raptor 150GB |2x Seagate 7200.10 320GB
    Print is dead. Kero-chan's Avatar
    NYC Public Library
    Quote Originally Posted by PointlesS
    full protonic reversal.
    Batou's evil twin
    Quote Originally Posted by Concerned Citizen View Post
    im a homosexual but i disliike obama for his non-*** policies
    I'm happy for you. Why don't you go pick up a case of AIDS.
    ... Reign's Avatar
    Nov 2002
    Europe
    Quote Originally Posted by Kero-chan
    haha, and then your avatar with the ghost busters :P that's classic
    Tiger Shark anubis44's Avatar
    Ottawa, Canada
    Or a complete inversion of the time/space continuum. One or the other.
    Seriously though, the reduction of memory speed is terribly unacceptable on this PowerColor card. The main thing that really separates the 4850 from the 4870 is memory bandwidth (yes, and a bit higher core speed on the 4870, but really, the R770 is much more memory bandwidth starved than anything else). If you threw, say 1Gb of 2500MHz-3000MHz (effective) DDR3 onto an overclocked 4850 card, THEN you'd have something worth paying a little more money for, and would close the gap somewhat more on the 4870.
    AMD Phenom II X2 550BE@X4 (4cores unlocked) 3.82GHz (1.456V); Zalman CNPS 10X Quiet; 4Gb Kingston DDR2-800; 2x4850 512MB Crossfired
    In response to some positive words about Stalin: "If Hitler invaded Hell, I would at least make a favourable reference to the Devil in the House of Commons." -- Winston Churchill
    magniloquent prick
    3000mhz gddr3? puff puff pass, man.
    Maybe he meant GDDR5?
    Ottawa, Canada
    Quote Originally Posted by iamsostupid
    No, I did mean GDDR3. I know it doesn't currently exist, and I was speaking hypothetically. I was positing a custom or O/C'd version of the 4850 that WOULD make sense to pay a little extra for.
    If you pair GDDR5 with an RV770 chip, you're just making a 4870 card.
    magniloquent prick
    so, GDDR3 is going to experience a 50% jolt in performance even though it's technically at its manufacturing limits? or this is your "dream 4850 card" that will end up costing more than a 4870 X2 to manufacture...
    Ottawa, Canada
    Your title notwithstanding, it would be nice if you'd stop acting like an a$$ yourself (since you seem to be enamoured with donkeys) and lurking in every thread on this forum just looking for an opportunity to mindlessly attack me. If you're angling for the title of 'MegaTroll', you've certainly got my vote already. In fact, you're beginning to temp me into forging several fake IDs so I can vote several times over for you for this position.
    In case you don't know what the word 'hypothetical' means, here's a definition:
    "hy·po·thet·i·cal haɪpəˈθɛtɪkəl/ Pronunciation Key - Show Spelled Pronunciation[hahy-puh-thet-i-kuhl]
    –adjective
    1. assumed by hypothesis; supposed: a hypothetical case.
    2. of, pertaining to, involving, or characterized by hypothesis: hypothetical reasoning.
    3. given to making hypotheses.
    4. Logic. a. (of a proposition) highly conjectural; not well supported by available evidence.
    b. (of a proposition or syllogism) conditional.
    –noun 5. a hypothetical situation, instance, etc.: The Secretary of Defense refused to discuss hypotheticals with the reporters.
    Also, hy·po·thet·ic (for defs. 1–4).
    [Origin: 1580–90; < Gk hypothetik(&#243;s) supposed (hypo- hypo- + the- put (base of tith&#233;nai to put, do1) + -tikos -tic) + -al1]
    So my point wasn't that GDDR3 exists at 2500-3000MHz, or even that it ever will. Rather, I was pointing out that even 2Gb of ram clocked at 1800MHz will hurt the performance of that card so much that I don't think it's worthwhile. If you don't like me saying this, well, nobody asked you anyhow. The other point I'm making is that 2500MHz-WORTH of DDR3 speed is the KIND of speed improvement I'd like to see if I were to spend extra money on a 4850 card. Unless, of course, there's a way to use some other type of ram to get equivalent or better throughput without resorting to GDDR5, like the 4870 has. Have I spelled it out simply enough for you to comprehend now?
    If you haven't got anything better to do than to hound my every post on the Sharky Forums, that's pretty sad. Judging by your ~4,500 posts, it would appear I may be correct. Some people have a little bit TOO much time on their hands, and it tends to drive them kinda stark raving mad. I'm all for enthusiastic participation, but... unless you're a moderator on here, there's a limit, man.
    magniloquent prick
    you said it would make sense to pay for it. didn't know what you meant.
