WinXP PC not communicating with PS3 over wireless router
Results 1 to 6 of 6
Thread: WinXP PC not communicating with PS3 over wireless router
    Fuquay-Varina, NC, USA
    OK here's the setup - My Acer (2006) windows xp home notebook and my newly bought secondhand ps3 (40gb). they are both connected to our belkin dfn7230-4 wireless router. my bud's mac, also connected wirelessly, will talk to the ps3 and stream files to it no problem - but my windows xp pc will not broadcast the media server. intel 845g pro wireless adapter.
    network is configured with WPA2 protection.
    UPNP is enabled on the router, and ps3 test shows UPNP as available. PS3 connects to PS network and browses internet fine.
    ssid service, upnp, windows media networking services all are on automatic, and started.
    are there any tools that can tell me if upnp is working on my computer? or can tell me if there might be a firewall blocking the data? i have tried disabling windows build-in firewall, but this has no effect. have tried putting the ps3 in dmz, then the pc in dmz instead. no go.
    i am open to any suggestions. please ask for any more information needed.
    Thanks in advance.
    Mako Shark kent1146's Avatar
    Mar 2004
    NYC
    Laptop Madness (w/unboxing pics): | 17 Second Boot - POST to Desktop | SSD Boots Windows 7 + Load 27 Apps in 1 Minute | SSD vs HDD Direct Comparison - Identical Drive Images
    Alienware M11x R2 | Core i5 520UM | 4GB RAM | OCZ Vertex 2 120GB SSD | nVidia GeForce 335M GPU | 11.6" WLED Display | Etymotic ER-4P Headphones | 4.5lbs
    I'm sure someone else here has got some quality input on the matter.
    AMD Athlon Xp Barton 2500
    Epox 8RDA3+
    512mb pc-3200
    XFX Geforce FX 5900nu
    Sound Blaster Audigy
    Maxtor 80gb 7200rpm
    Western Digital 100gb
    Western Digital 80gb
    Mar 2004
    NYC
    No, seriously. Use my LMGTFY link, and click on the first result. It gives step-by-step instructions on how to do what it is that you want.
    Please, is it not obvious that the problem is more complicated than searching google for a simple how-to?
    Epox 8RDA3+
    512mb pc-3200
    Maxtor 80gb 7200rpm
    Problem solved by installing Windows 7.
    Epox 8RDA3+
    512mb pc-3200
    Maxtor 80gb 7200rpm
