06-17-2012, 10:14 PM
#1546
Originally Posted by monroeski on 10/16/2011
What are you doing up there sheep there's no grass and you're just getting wet
This is from about two weeks ago.
06-18-2012, 10:59 PM
#1547
Has got that jut
Comp - i7 950, Radeon HD 5870, 6gb DDR3 1600
Currently Playing - Gravity Rush 2, DOOM (2017), Nex Machina
Currently Reading - Dracula by Bram Stoker
06-20-2012, 10:56 PM
#1548
http://i.imgur.com/TAW5I.jpg
http://i.imgur.com/RUeas.jpg
Been messing around in creative mode. Survival is fun most of the time, but I get tired of having to farm mats just to build simple things.
New Build (Oct. 2012)
-[ ASUS P8Z77-V |:| Intel Core i5-3550 |:| 16GB (2x8) Corsair Vengeance LP |:| EVGA GeForce GTX 660 2GB |:| Samsung 830 256GB |:| Windows 7 ]-
Currently Playing
-[ Sleeping Dogs |:| Guild Wars 2 |:| Torchlight 2 ]-
06-21-2012, 09:05 AM
#1549
InsidiousIntent: I moved 3 more last night and it still wasn't enough.
Also a creeper showed up while I was redoing the water, so I think we lost a few of the minecart tracks (I fixed the area though); and, I switched to glass panes near the bottom of the ladder so you can (maybe) get a better estimate of what's down in there now.
06-24-2012, 12:10 AM
#1550
06-25-2012, 06:56 AM
#1551
The gate of the castle is busted. The switch on the outside wasn't working and I tried to fix it, there was lava in one of the passages and had cut the redstone connection. Next thing I know 2 creepers join me in the fixing attempt and blow half the gate mechanics out, I need help fixing it as I'm not too adept with pistons and redstone in general. (Happened a few days ago, if someone fixed it already, disregard this post)
06-25-2012, 10:09 AM
#1552
Man it took me a while to build that logic. I got pretty good at it at the time, but it will take some brushing up to rebuild the circuit.
*edit* Got the room cleared of lava. I'm thinking I may tunnel downward and create a safer room from which I can route the primary logic. Made wide enough, I should be able to run pathing alongside it for each gate as well, which was originally a tough issue (had to run a small tunnel underneath the circuit just to connect the front as input).
<!-- caffeine break. -->
07-02-2012, 07:11 AM
#1553
Note:
Minecraft server (Sharky Adventure) is currently down. You can view the map here, but I've stop the server until I can figure out what is going on with it. Apparently it's been down for a day or two, but I've been out of the country. I'll look at it when I get home from work tonight.
Edit: Seems it freaked out when the leap second happened. Not sure how to fix this. I'll hit up Notch on twitter I guess or do a search at work today.
07-02-2012, 09:02 AM
#1554
Awesome.
Originally Posted by James
leap second
I did not know this was a thing. Thank you for bringing me knowledge.
07-02-2012, 10:56 AM
#1555
http://www.guardian.co.uk/technology...-qantas-reddit
That's just crazy.
Also, http://blog.mozilla.org/it/2012/06/3...u-and-the-fix/
* and a bunch of our IT guys have personal, at-home minecraft servers, which were also similarly affected.
Reason: 2nd link
07-02-2012, 11:49 AM
#1556
Originally Posted by linoleum
Just found that link on my own as well. I will try the fix when I get home. As it is exactly what is happening. Java spins out to 10x CPU load quickly for no reason, then complains that it can't keep up.
And Kama, I didn't realize it either until I caught an article on it from one of my news feeds. Leap Seconds to offset the time skew caused by the deceleration of the earth's rotation. Just crazy.
Seems that there are definite fixes available which I might implement. NIST has offered a file and there is an NTP config you can do to make use of it so that in the future it works correctly.
http://support.ntp.org/bin/view/Supp...P#Section_6.14.
ftp://tycho.usno.navy.mil/pub/ntp/le...nds.3535142400
07-02-2012, 01:43 PM
#1557
Awesome.
I'm just glad the leap second didn't affect any of our customers or else my weekend would have been painful!
07-02-2012, 06:13 PM
#1558
07-05-2012, 08:55 PM
#1559
nuclear launch detected
server: mc.westeroscraft.com
type: "/warp room"
mind = blown
bitfenix prodigy, i5 4670k, asrock z87e-itx, zotac gtx 970, crucial m500 msata, seasonic x650, dell st2220t
07-09-2012, 02:13 PM
#1560
Finally got some time to fix this over the weekend. I excavated the area under the gate in order to make some more room and surrounded the circuit with obsidian/metal bars. Ran the paths beside that and routed them upward. If the input or output lines get messed up again, they will be easy to fix.
So the city gate is operable again.
