Results 1 to 12 of 12
    Aug 2004
    Urbana, IL
    iPad Wifi Question
    I bought an iPad for really cheap. The person said the wifi was grayed out. The price was worth it even if I couldn't get the wifi working again. I got the ipad today and tried doing a few software things to it. I tried resetting the network settings. I restored the factory settings all together and I reinstalled the OS.
    None of that worked. The Wifi and bluetooth are still grayed out. So I started looking around the internet and found out that the wifi Broadcom chip is embedded in the data cord port assembly. I can buy that part for around 30 dollars. To install the part I don't even have to take out the batteries to get to the chip. I only need to pop the case off and undo a few screws.
    Before I jump on trying this out (for fun mostly), is there anything else you guys could suggest? I would hate to dig into hardware when it may be a software issue.
    Thanks!
    Main Rig: Watercooled
    EVGA 680GTX | Intel 320 SSD + Crucial M4 256GB | Corsair 750TX | Corsair 800D
    Hackintosh Workstation: Aircooled
    EVGA 640 GT | WD RE4 500GB | PCP&C 600W | G5 Case
    Toys:
    iPhone 4 | iPad 3 | PS3 | Xbox 360 | PSP-3000 | Supermicro based NAS | Steelcase LEAP!
    Currently playing: Guild Wars 2
    Last Game Beaten: Walking Dead EP1
    LOLWUT ImaNihilist's Avatar
    San Francisco
    If you wipe the device and reinstall the OS, it isn't a software issue. I've never seen a software issue like this.
    You can take it into the Apple Store and see if they will waive the diagnostic fee, and they can tell you what's wrong with it.
    I've had the wifi chip die on an iPad, iPod Touch and MacBook Pro. Same issue on the iPad and iPod Touch, on the MacBook Pro the icons disappeared entirely from the System Preferences.
    Aug 2004
    Urbana, IL
    It seems this issue happens a lot of 1st gen iPads. Is it as easy as replacing the part if it is a hardware issue?
    Toys:
    San Francisco
    Quote Originally Posted by Timman_24 View Post
    If that is the issue, yes, it's as easy as replacing the part. I've never opened up an iPad though. I would have assumed the chip was integrated…I guess not.
    On MacBook Pros the chip is located in the bottom part of the monitor housing. When you use the computer with the lid closed constantly it tends to generate too much heat and it kills the chip. I suspect the same thing happens with the iPad, since iPads tend to get pretty damn hot.
    The wifi on my iPod Touch died after I left something looping and it got really hot.
    Aug 2004
    Urbana, IL
    Thanks for the info. The chip is actually attached to the data sync cable connector. The main chips on the motherboard are the processor, I/O chips, and memory. The 3G and Wifi/bluetooth chips are on daughter boards.
    About the heat, that could definitely be the issue. The wifi chip is located right between the two battery packs in the middle of the device.
    Actually, if you scroll down to step 18/19 you can see where it is located. I found the entire data cable assembly with the wifi chip attached on the internet. I ordered one with the appropriate torx tool and a specialized tool to open the case. I also ordered more retention clips in case some break.
    It will be interesting, hopefully I can fix it.
    My main concern was if Apple signs each component to that specific device to limit aftermarket repair. I'm glad to hear it is easy to swap parts out.
    Toys:
    Hammerhead Shark Nabby's Avatar
    Legoland
    Go to the Apple store and talk to them about it. They may swap it out for you. The whole iPad, regardless of warranty. I've seen this happen a few times with friends of mine and their iPhone/iPad. Either way it doesn't hurt to try.
    Edit:
    Also, make sure to make an appointment it will help.
    Antec Three Hundred Two | Intel DP67BA | Intel 2600k | Corsair CWCH60 | CORSAIR Vengeance 16GB (PC3-12800) | PNY GTX 580 | Samsung 830 256GB SSD | WD RE4 2TB (WD2002FYPS) | Asus Xonar DG Sound | LG Blu-Ray Burner | Windows 7 Ultimate x64
    Work:
    Macbook Pro 15" Retina Display | 8GB Ram | 256GB SSD | Mac OS 10.8
    San Francisco
    I can't speak to the iPad, but I know on the MacBooks in particular there are A LOT of different serials for parts that match a specific part number. That is, they iterate several times on part design. There are like 20 different version of the glass trackpad for the MacBook now. It's mostly the same part, but you do notice small changes from time to time. The OS recognizes it the same way.
    Aug 2004
    Urbana, IL
    I guess there isn't a "Genius" Bar in my area. There is a retail Apple store, but I guess they don't all have the diagnostic support.
    EDIT: Ahhh, it is an authorized Apple Store, not a "real" Apple Store.
    Toys:
    Legoland
    Bah, boned. Well, then replacing it may be a good option. I've managed to screw up an iphone opening it up so do be careful.
    Work:
    Aug 2004
    Urbana, IL
    Holy crap! I opened it up, install the data cable with wifi module, and reset the ipad. I have wifi!
    I gave this repair about a 1% chance of working.
    Total into the ipad: 210
    Not bad
    Toys:
    Legoland
    Not bad
    Not bad at all, well done.
    Work:
    Houston, we have lift off!
    Good job!!
    8 GB Corsair Vengeance DDR3-1600|Antec TruePower Trio 550W
    MSI R6850 PE/OC (860/1100)|Catalyst 12.4|Acer 20"
    16 GB G.Skill Ares DDR3-1866|Corsair AX850
    Asus HD 7850|Catalyst 13.1|X-Fi XtremeMusic
    Klipsch ProMedia 2.1|Sennheiser HD-580
    Logitech WingMan RumblePad USB|Logitech G5
    Win 7 Home SP1|APC SmartUPS SUA1500
    Heatware & eBay | the Gamer Planet | XFire
