Advice On First Computer Build?
Results 1 to 11 of 11
Thread: Advice On First Computer Build?
    Mar 2012
    Hello, I am looking to build my first computer, I am a huge gamer and wanted to build my own to make it the specs I want and such. My uncle recommended this site so I figured I would ask some questions. My budget is $2,000 and here is a list of parts that I have so far:
    Motherboard: ASUS Crosshair V Formula AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS
    Video Card: EVGA 03G-P3-1584-AR GeForce GTX 580 (Fermi)
    Processor: AMD FX-8120 Zambezi (Eight-Core)
    RAM: CORSAIR Vengeance CMZ16GX3M4A1600C9 16GB (4 x 4GB) 240-Pin DDR3 SDRAM (x2 For 32GBs)
    Case: COOLER MASTER HAF X RC-942-KKN1
    Power Supply: NZXT HALE82 HALE82-650-M
    Hard Drive: Samsung by Seagate HD502HJ/ST500DM005 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive(x2
    Optical Drive: ASUS DRW-24B1ST/BLK/B/AS
    Sound Card: ASUS Xonar DX 7.1 Channels PCI Express x1 Interface Sound Card
    CPU Cooler: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1
    Operating System: Microsoft Windows 7 Professional
    On Newegg.com this comes to just over $1,900.
    Please leave your input, advice, what you think I should keep, change or anything I might be missing. Thanks.
    Quote Originally Posted by EchoVG View Post
    Welcome to Sharky's Echo!
    Right now, sadly in the world of consumer gaming PC's, Intel beats the pants off of AMD when it comes to performance per $ and performance per watt. That means not only will an Intel CPU be faster, it will consume less energy both during idle/sleep times and during full load.
    You obviously are trying to build quite the beast of a rig for your first time out. I commend you!
    A couple of notes:
    1. Most modern motherboards only accept 4 DIMM's of memory. High end Intel boards take 8 DIMM's, and older (X58 chipset based) ones take up to 6 DIMM's. You're 4x4GB DIMM kits x2 would probably not be worth it.
    2. Hard drives are much more expensive than they used to be. 500GB x2 is commendable, but probably not worth the price vs. the performance boost you might get. (Unless you are running RAID1 for data security, in which case.... Still not sure if it's worth the price. )
    3. Most motherboards have decent-to-high quality sound cards onboard. They aren't perfect but might be worth starting with before you spend the money on a dedicated sound card.
    4. Finally, if you aren't in a huge rush, Ivy Bridge (new generation Intel CPU's and their attending chipsets) are due to be launched sometime between April and June. If you can wait, this will push existing solutions down in price, and does offer the chance at the absolute bleeding edge if you want to go that route.
    If I might counter offer what you have proposed, here is a rig that will tear through all of your games with ease, and should only require video card upgrades over the next few years. Keep in mind: This is my recommendation based on quality components, but there are a few personal preferences included as well. you can always modify it to suit your tastes.
    http://secure.newegg.com/WishList/Pu...umber=19819166
    Code:
    Case & PSU:
    100	Fractal Design Arc Midi ATX mid-tower case
    211	850w Seasonic X-850 PSU
    Components:
    350	GTX570 EVGA Superclocked video card
    325	i7-2600K Intel CPU 4C/8T @3.4GHz
    190	Asus P8Z68-V/Gen3 motherboard
    78	16GB (2x 8GB [2x4GB] kits) DDR3-1600
    269	240GB Mushkin Chronos SSD (SATA3)
    115	1TB Seagate 7200rpm hdd (SATA3)
    80	Lite-ON Bluray burner (SATA)
    Software:
    140	Windows 7 Professional 64-bit OEM
    1858	Total before shipping.
    30	Shipping & Handling
    1888	Grand Total
    *Edit: As an explanation: You will find that an SSD will radically shift the way you interact with a lot of your daily tasks, including gaming.
    Intel i7-2600K | Asus P8Z77-V | Samsung 840 Pro 256GB SSD
    16GB PC3-12800 Kingston DDR3 | MSI GTX 760
    Fractal Arc Midi |Seasonic X650 PSU | Klipsch ProMedia 5.1 Ultra | Windows 8.1 Pro x64
    Hammerhead Shark Trunks's Avatar
    Sep 2002
    Fremont, California
    Case: Antec DF-85 - $129.99
    PSU - Antec CP-1000 - $149.99
    CPU - Intel Core i7-2600k - $324.99
    CPU Cooler - EVGA Superclock CPU Cooler - $49.99
    Motherboard - ASUS Maximus IV Extreme - $$289.99
    Memory - Corsair Vengeance 16GB (4x4GB) DDR3 1600 - $98.99
    Video Card - ASUS ENGTX580 1.5GB - $499.99
    SSD - Crucial M4 128GB - $174.99
    HDD - Seagate Barracude 6.0GB/s 2TB - $119.99
    DVD Burner - Lite On Combo Drive - $17.99
    Blu Ray Drive - Lite-On Internal 12x Drive - $59.99
    Monitor - ASUS VS248H-P 24" LCD - $199.99
    $2116.88. Couple hundred more than what you had, loads better in performance. You could always go with a pre-fabbed water cooling kit such as the Swiftech H20-X20 kits, they look nice.
    Intel Core i5 2500k @ 4.5Ghz, MSI P67A-C43, Antec Kuhler 920, 16GB (4x4GB) Patriot G2 DDR3 1600, Sapphire Reference R9 290x, Samsung 840 Series 120GB SSD, Seagate 1TB HDD, Antec 650 Earthwatts, Antec 300, Corsair Vengeance K95 + M90
    Late 2009 21.5" iMac - 3.06ghz C2D, NVidia 9400m, 4gb RAM, 500gb Hard Drive, Magic Mouse
    Steam ID - Entrical85
    PSN ID - Entrical
    Currently playing: MLB 14: The Show
    VA
    Agree with 2x8 gig memory. DDR3 is so cheap right now. Hard drive prices are so high right now. I am guessing they will try to keep them up there as long as possible. I know it is only about 40USD difference but why does he need Win 7 professional over home edition to game?
    Quote Originally Posted by drdoom View Post
    The main reason I recommend Pro vs. Home to anyone is the ability to do backups to network drives. Even if you just have a cheapo 1-2 drive NAS on the network, it's still worlds easier than constantly having to connect a USB drive for the backup. (In my mind.)
    Great White Shark mikeysg's Avatar
    May 2003
    Quote Originally Posted by Trunks View Post
    Great system, but I would change one thing, the vid card. Either max it with a GTX680 2gb or go for a lower priced HD7950 3gb (~$460 @newegg). The HD7950 trades more wins against the GTX580 plus it has 3gb of VRAM. I honestly believe that more and more games would require more VRAM to max them out @1080P.
    Aug 2004
    Urbana, IL
    I'd pay the 30 more for the 680. It is quite a bit faster than the 7950.
    PC: Corsair 550D
    4280k | Asus Rampage Gene | Mushkin 4x4GB | EVGA 780
    Intel 120GB SSD + 2TB Seagate | Seasonic 660 Plat
    2x Alphacool XT45 | Laing DDC | Bitspower
    Currently playing: Civ 5
    Last Game Beaten: Walking Dead
    Mar 2005
    NY
    Quote Originally Posted by James View Post
    I would have to say, get the SSD as the primary and install another internal hard drive(s) for data storage and backups.
    MOBO: GA-Z68X-UD3H-B3
    CPU: i7-2700K
    RAM: G.SKILL Ripjaws X 16GB (2 x 8GB)
    CPU COOLING:Corsair Hydro H80i
    VIDEO: MSI TF 2GD5/OC GeForce GTX 760 OC N760 in SLI
    HDD: Intel 320-160GB SSD
    HDD: Samsung 840 250GB SSD
    MEDIA: Plextor Dual DVD
    PSU: CORSAIR HX750W
    CASE: Antec Twelve Hundred V3 Full Tower
    OS: WIN 7 x64 Home Premium
    Monitor: Westinghouse 32" LCD 1080p
    Mar 2012
    Hello everyone! Sorry I have been away from the forums awhile lol. Thank you all for the advice, I will take most of it into consideration
    Mako Shark Learux's Avatar
    Santa Clarita ,CA
    My vote on the 680, I would like AMD to win but can't recommend them here.
    GA-MA790GPT-UD3H, AMD Phenom ll 955,
    Lian Li PC-60 PLUS, HD5850
    Resist the devil, and he will flee from you!
    "Congress shall make no law respecting an establishment of religion."
    When thou seest an eagle, thou seest a portion of genius; lift up thy head!
    2kr1b1r/Bpp3pp/1N2p1n1/4p1q1/4P3/2Q5/PPP2PPP/3R1RK1 b - - 6 15
    Mar 2005
    NY
    If you are going Win 7 Pro, then it doesn't make sense to waste the RAM slots like that. Stick with Home Premium if you are only going to max out at 16GB. But your mobo supports 32GB and as people have said RAM is cheap. I would get Gskill Ripjaws at 8GB sticks.
    I've always have been an intel fan. I would say go i7. I also agree with the GTX 680. If you are a serious gamer, then it only makes sense to go with the best gaming materials. Having a good power supply is very important so I would say go with this one:
    CORSAIR Professional Series HX850 (CMPSU-850HX) 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply
    the 650W IMO is not going to be strong enough.
    What you can do is start low on the RAM and build up as time goes on.
    CPU: i7-2700K
    PSU: CORSAIR HX750W
