Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
    Sub $1/GB for Mushkin Chronos 240GB SSD
    It's finally time for those who said "I'll buy an SSD once it drops below $1/GB".
    Mushkin Chronos 240GB SSD for $238
    It's using Async NAND. So it's middle of the road of the current 6Gbps SF-2281 based SSD performance ranges, but it's not terrible by any means.
    Great for a secondary SSD, or your first if you just want a switch from spinning media.
    *Edit: If you do the math, it's officially 99.17 cents per GB.
    nuclear launch detected kpxgq's Avatar
    texas
    im starting to hit about 90% capacity on my current main SSD... corsair force3 120gb... so im really itching for a 240gb deal... however, i want synchronous nand for the performance jump as well
    i do have a spare SSD (corsair force1 120gb)... so im wondering if i can/should just RAID-0 the 2 drives i have for 240GB... anyone know if this would work since one is a sandforce1 SATA2 drive and the other is a sandforce2 SATA3 drive?
    intel i5 3570k, msi z77ma, msi gtx 660, 256gb samsung 830, 16gb samsung 30nm ddr3, seasonic x650, dell u2311h
    Quote Originally Posted by kpxgq View Post
    You're combined speed will be limited to the slowest in the group, and that's assuming that your controller can regulate properly. It is never really a good thing to mix speeds of drives, even spinning ones.
    texas
    yeah thats what i figure... i will probably sell my 2 drives:
    - corsair force3 120gb should fetch about $130
    - corsair force1 120gb should fetch about $100
    that gives me ~$200 to grab a synchronous nand sandforce3 drive and eat ~$100 or a 180gb synchronous nand drive is around $250
    Both the Sync NAND (Chronos Deluxe) and the aSync NAND (Chronos) drives are estimated to be back in stock tomorrow!!!!!
    I'm definitely gonna get one of the Sync NAND's if I can. Even at $278/240GB it's a heck of a deal at $1.16/GB.
    texas
    i was about to jump on this force gt 240gb (sync nand) for $290 deal after rebate... your deal looks better
    http://www.newegg.com/Product/Produc...82E16820233208
    In stock!
    texas
    yeah i grabbed the 240gb chronos (async) for ~$240.. i really wanted a toggle nand version (chronos deluxe, patriot wildfire) but couldnt justify the $50-80 premium... i think i will wait until SATA4 for the next big speed increase... i would like to see sustained 500MB/sec across all benchmarks not just in 1 or 2 scenarios
    High performance model is in stock now!
    texas
    ok time for some benchmarks!
    mushkin chronos 240gb in my main rig... not as fast as the deluxe but still blazing!
    crucial m4 64gb in my netbook... you can see how much SATA2 and the less NAND chips affects performance here... im guessing it should be double this if i had the 128gb version in my main rig. but check out that ridiculous 4k-64 read test.
    Since it's SATA2 and that score is not possible, did you try a 2nd run to verify? lol
    Otherwise, awesome man. Seems like even the "mainstream" chronos is a good deal.
    Invisible Modfish Vindir's Avatar
    Georgia
    For anyone wanting the Chronos Deluxe, here is a quick bench done while doing a mint install.
    Code:
    mint@mint ~/Downloads $ sudo hdparm -Tt /dev/sda
    /dev/sda:
     Timing cached reads:   29836 MB in  2.00 seconds = 14934.39 MB/sec
     Timing buffered disk reads: 1102 MB in  3.00 seconds = 366.84 MB/sec
    mint@mint ~/Downloads $ sudo ./seeker /dev/sda
    Seeker v2.0, 2007-01-15, http://www.linuxinsight.com/how_fast_is_your_disk.html
    Benchmarking /dev/sda [228936MB], wait 30 seconds..............................
    Results: 7735 seeks/second, 0.13 ms random access time
    Mako Shark mynameis's Avatar
    Indianapolis, IN
    I always said I would wait for that price point but I ended up buying a bit before. I do still need one for my laptop though...
    MacBook Pro 13-inch, 2.3Ghz i5, 8GB RAM, 640GB HD
    Desktop: i5 2500K (w/ CM Hyper 212 Plus) , 16GB DDR3, 240GB OCZ Agility SSD, 2x1TB in RAID0, eVGA GeForce GTX 570, Corsair TX750M PSU, ASUS Sabertooth P67, Dell 2209WA eIPS LCD
    Home Server: Intel Pentium G630, ASRock H61M/U3S3, 4GB RAM, 80GB + 2TB HD
    texas
    New egg has the agility 3 240gb for $210 after rebate and includes mass effect 3 ($50 game)
    Georgia
    That didn't seem to last the day. It's 250 after rebate now and the mass effect is gone.
