    Mako Shark wh666-666's Avatar
    Jul 2006
    In a red kennel
    Which OS for this system?
    Hey all,
    A bit of a question. At the moment, I have several databases on my server as well as other things.
    The problem is, if I want to dump some files back on the server, update a customer record or alter stock in my supplies, I have to start up a computer and everything which is a pain and it results in things not getting updated properly or as often as it should.
    So what I want is a small PC, very low in power, connected to the main TV in the house with a wireless keyboard and a barcode scanner that I have hooked up.
    Then all I have to do when I come in is pop the TV on, which usually does get turned on at some point, scan a barcode if Im taking something out of my supply cupboard or update something quickly or dump a file on there to then organise later.
    So as for hardware, I was thinking of a Raspberry. However the problem is, my databases are mdb's (MS Access). So since it ships with linux, I need a good free alternative to MS Access for linux. If that doesnt exist, I believe windows CE will work on the system? If so, does it just use win2k/xp drivers or a completely different type of drivers for hardware? I presume MS Access works on windows CE?
    Quote Originally Posted by wh666-666 View Post
    Hey all,
    WindowsCE/Embedded both use completely distinct drivers vs. XP/2K since it is designed to run on ARM, not x86.
    How low power are you trying to go? Would a board with a single core Atom or AMD APU work out in your power-envelope?
    Jul 2006
    In a red kennel
    Essential requirements:
    - Has to be completely fanless
    - As small as possible (needs to fit in a crowded area around digi-boxs or even behind a TV mount)
    - Has to be able to run and edit *.mdb's
    - Needs one rj45 jack and display output and two usb
    - Has to be able to cope with being on 24/7/365
    - If a suggestion that isnt a conventional PC is made, I need the device to stay connected to a home network (over rj45 would be more secure) and be able somehow to be readily available/always booted for instant access
    Desirable requirements:
    - Very low powered, as much as possible considering constant standby and utilisation
    - As cheap as possible (I have considered a tablet, but too pricey)
    That is about it really. I did initially look at itx atom boards but they were more expensive and bigger.
    picoATX, nanoITX, mini-ITX, etc. would all be viable for that.
    An Atom solution could easily be fanless and would provide more power than you need. When in a sleep state, it draws maybe 1-3w total for the system (assuming solid state storage locally).
    http://www.logicsupply.com/products/epia_p720_10 <- Seems like an ideal solution.
