Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 37
  1. #16
    Quote Originally Posted by Timman_24 View Post
    I'm most excited about nvidia now supporting over 2 monitors on a single card.
    Can you provide a few links to this? I saw a brief note about 3-display support, but I haven't been able to really find more details. Most of the reviews only touch on the fact that nVidia has some how solved driving more than 2 TMDS type displays at a time.
    *Edit: What I've been able to find.
    http://www.geforce.com/optimize/guid...80-surround/#1
    Quote Originally Posted by nvidia.com
    In 2D Surround, any combination of monitors that share common timings is perfectly acceptable, though each must have, at minimum, one DVI, HDMI, or DisplayPort connector. Aesthetically, identical monitors are preferable, but not a requirement.
    In 3D Vision Surround, each monitor must be an identical make and model, and you must use three matching digital connectors. We will go into detail below, but you may need additional adapters for this.
    The Accessory Display, the forth monitor, does not have to be identical to the three Surround displays, but does require one of the three possible connectors.
    In 3D Vision Surround, any monitor connected to the DisplayPort output must use a DisplayPort to Dual-Link DVI adapter so that all three monitors are using Dual-Link DVI.
  2. #17
    Aug 2004
    Urbana, IL
    Got her installed. One of my biggest complaints with the 470 is alleviated. The 470 did not downclock out of 3D mode when two displays were hooked up. This meant it idled at 600-700mhz with full vcore. I had to use a 3rd party program to force it into a lower state, but I had to remember to shut that off when watching video or playing games. So it was a big PITA. The 680GTX adjusts clocks down even with multiple displays, so that is fantastic.
    Wow I ran 3DMark11 and the max temperature was only in the 70's on the stock cooler. May not even need WC for this card.
    Main Rig: Watercooled
    EVGA 680GTX | Intel 320 SSD + Crucial M4 256GB | Corsair 750TX | Corsair 800D
    Hackintosh Workstation: Aircooled
    EVGA 640 GT | WD RE4 500GB | PCP&C 600W | G5 Case
    Toys:
    iPhone 4 | iPad 3 | PS3 | Xbox 360 | PSP-3000 | Supermicro based NAS | Steelcase LEAP!
    Currently playing: Guild Wars 2
    Last Game Beaten: Walking Dead EP1
  3. #18
    May 2003
    Yep, these newer cards load temp is about mid 70's or so. Welcome to the realm of maxed out gaming! Awesome card btw....
  4. #19
    Aug 2004
    Urbana, IL
    Played some TDU2 today. It is nice having the game completely maxed with FXAA and 8xAA on while the GPU load is only 70% while it is underclocking itself lol.
    This thing is total overkill at 1080p, but I'm thinking of either going 3x1080p surround or just getting one of those 2560x1440 korean monitors, OR maybe going all out and getting a 30" dell. Then Ivy Bridge is coming out in a few weeks, better start saving
    Dirt 3 with Ultra settings, FXAA, and 4XAA with Vsync locked a 60fps only had a GPU load of 55% which meant very low temps while playing. Smooth as butter.
    I've never seen Crysis on all Ultra settings. I literally turned everything up to max with AA and it runs fine. Crazy. Looks awesome. Can't believe this is a 4 year old game.
    Toys:
  5. #20
    Nerdy.......AND sexy dimmy32's Avatar
    Oct 2002
    Somewhere in Canada, eh ?
    nice ! how much of an improvement over your old 470 ?
    %-wise ?
    i5 2500K
    Gigabyte H67A-UD3H-B3
    8 GB Corsair XMS3 DDR3
    Evga GTX470
    Thermaltake Tsunami VA3000 aluminum case
    Silverstone Zeus 750W
    X-fi Gamer
    Altec Lansing MX 5021s
  6. #21
    Aug 2004
    Urbana, IL
    Quote Originally Posted by dimmy32 View Post
    %-wise ?
    Double the stock vs stock performance easily. My stock 470 did ~5000 in 3dMark11. The stock 680 hits 9800. My watercooled and majorly OCed 470 number were ~6300 in 3DMark11. I haven't tried OCing the 680 yet. I don't have any reason to try since it is so crazy fast right now.
    Realistically, the 470 struggled with Crysis on medium settings without any AA. The 680 does everything on ultra with AA and FXAA without any problem. It never dips below 50fps. I want to fire up Crysis 2 as I was never able to properly run that with the 470.
    The card is sipping only 180W at max load, which is crazy low. I haven't messed with the power settings, but you can get it to go up to 225W through the control panel to get a decent overclock.
    Toys:
  7. #22
    Oct 2002
    thats crazy better ! thanks ! I'll consider getting this card , most likely sometime this year.
    i5 2500K
    Evga GTX470
    X-fi Gamer
  8. #23
    Engineer credit to *****! flutie98's Avatar
    Mar 2002
    CNSE UAlbany
    That sounds great, If I hadn't just dropped a bunch on a new rifle I would have been all over one of these. My 6870 still doesnt churn out enough fps to play BF3 optimally.
    |Core i5 2500K @ 4.6GHz|MSI Z77-GD65|8.0GB G.skill DDR3 1600|XFX AMD 6870|
    |Samsung 830 SSD|HP LP2465 24" LCD|Antec P280|Seasonic X750 PSU|H2O Cooling|Windows 7 x64|
    |Core i3 2100|ASRock H61-GM|8.0GB DDR3|AMD Radeon 6450|Kingston V100+ SSD|
    |Antec Fusion V2|Epson 8350 1080P 3LCD on 100" EliteScreen|
    |ThinkPad T420|Core i5 2520M|8.0GB DDR3|OCZ Vertex 4|
    Audio: Radeon 6450 (HDMI)->Onkyo TX-NR509 ->Polk M60/M30/CSII + Velodyne VX10
  9. #24
    Aug 2004
    Urbana, IL
    Spent some more time with it last night. This card is a pretty large departure from traditional video cards. There is a lot of tech going on in the back ground, and people don't quite know what to make of it yet. The overclocking can only be done via offsets, but they give strange results. You actually change what the "potential" of the card is, not the actual clocks.
    The card uses an algorithm to determine the best load, voltage, and clocks depending on the heat, demand, fan setting, and numerous other mysterious factors right now. For stock performance, this is fantastic since the card only has to run as fast as needed, which saves power and prevents unneeded heat. For overclocking though, there are a lot of parameters that people are trying to figure out such as setting the fan to 65% gives a much better overclock. Not because of temperature, but because of a value in the algorithm.
    Also, it has been shown that more voltage at a slightly higher temp will bring clocks down quite a bit. Too low of a temp and clocks seems to lock in. Right now it is all over the place. I can't wait for someone to crack the best way to overclock, because it will surely involve huge flow charts lol.
    I don't mind right now because this thing smokes everything I throw at it with stock performance.
    BTW, here is a pic of it in my comp:
    Toys:
  10. #25
    Digging the LED lit pump lid. That's pretty sweet looking.
  11. #26
    Aug 2004
    Urbana, IL
    Quote Originally Posted by James View Post
    Thanks, radioshack LEDs wired to a Molex adapter The blue ones are expensive haha.
    Toys:
  12. #27
    May 2003
    Ooooooh, VERY NICE!!!
    Damn, I don't have the talent to do such nice work....
  13. #28
    Aug 2004
    Urbana, IL
    Quote Originally Posted by mikeysg View Post
    Eh, anyone that can solder two wires together can create arrays of LEDs. The hardest part is making it look decent. I still fumble my way around sleeving wires.
    Toys:
  14. #29
    "Watches You Sleep" Shark taggart6's Avatar
    Oct 2003
    running a 4870 that is starting to show its age. Thinking of grabbing this for my birthday. looks hot!
  15. #30
    Super Villain Moderator Un4given's Avatar
    Congrats. My Q6600 is starting to show its age, so I'm in the process of rebuilding my system, so I will have to stick with my 6970 (BIOS modded 6950) for now.
    Intel i7 3.2GHz @ 3.93GHz
