Results 1 to 11 of 11
    VA
    Will 8 gigs of memory cause any issues with WinXP?
    I want to run a triple boot system with Windows XP booting from one hard drive and Win&/Linux booting from separate partitions on another. I have an extra 4 gigs of memory I want to add. I assume if I add it then XP will just not see the extra ram.
    Administrator Steve R Jones's Avatar
    Dallas, TX
    XP won't care.... The other apps probably won't care either and you'll be wasting your time Unless of course you're using some really ram hungry linux apps.
    It can cause memory faults if you are running XP 32-bit. XP 64-bit will accept 8GB of RAM happily. At least that is my experience. (Admittedly, I've had limited experience with 32-bit XP.)
    If you aren't spending all of your time in it, it's probably not an issue to worry about.
    VA
    Not sure how much time I will be spending on each OS yet. I got the ram a while ago for another computer but never used it so it's just sitting around at the moment.
    Use it for sure. Worst thing that can happen is you either take it out or don't boot into XP.
    Mar 2005
    NY
    32bit will only recognize 3.25GB OK. 64 Bit Win 7 home premium can see 16GB. Win 7 pro, ultimate can see as much as you can fit.
    MOBO: Biostar TZ68K+ Intel Z68 ATX
    CPU: Intel Core i7-2700K
    RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB)
    CPU COOLING:Corsair Hydro Series H80
    VIDEO: MSI TWIN FROZR II GeForce GTX 570
    HDD: Intel 320-160GB SSD
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    MEDIA: Plextor Dual DVD
    PSU: CORSAIR HX750 750W
    CASE: Antec Twelve Hundred V3 ATX Full Tower
    OS: WIN 7 x64 Home Premium
    Monitor: Westinghouse 32" LCD 1080p
    Mako Shark wh666-666's Avatar
    Jul 2006
    In a red kennel
    Quote Originally Posted by drdoom View Post
    Quote Originally Posted by kujoe2002 View Post
    Doom, as Kujoe said, XP 32 or 64 bit wont see all the ram.
    What I would do if you're using that much memory, is only have the one OS on your HDD, just a linux distro.
    Then install sun virtualbox and virtualise XP. You can then dedicate as much memory and HDD space as you want, without ever having to resize partitions or muck about.
    Quote Originally Posted by wh666-666 View Post
    XP Pro 64-bit will see all the RAM just fine.
    Quote Originally Posted by microsoft.com
    Code:
    Version 	Limit on X86 	Limit on X64
    Windows XP 	4 GB 		128 GB
    LOLWUT ImaNihilist's Avatar
    San Francisco
    A 32-bit *nix distro won't be able to use all the RAM either.
    VA
    I thought about that a little while ago and installed virtualbox but I didn't go any further. WinXP is installed on a separate partition on one hard drive. I have no desire to mess with that drive as it is setup and working the way I want it to at the moment. Win7/Linux are going on a separate hard drive that is empty at the moment. I only got Win7 so I can play DX11 games I do not have plans to use it for anything else. I'd like to get Win7/linux running. If I ever get time I can rearrange my hard drives and maybe give each it's own partition on my main 1 TB hard drive.
    Mar 2001
    Littleton, CO
    This is probably true in many cases, but, in reality, it depends on what other hardware requires addressable memory space. The last 32 bit Windows install I ran saw more than 3.5GB of the installed 4GB.
    Quote Originally Posted by ImaNihilist View Post
    Any recent 32-bit *nix distro will likely support PAE (36-bits or 64 GB of addressable memory).
    Nick_B
    Currently running Ubuntu and Windows 7.
