Thread: XBOX HDMI cable
    Great White Shark Thermo's Avatar
    SE PA
    XBOX HDMI cable
    Does an XBOX 360 require a special HDMI cable? Or will any hi quality HDMI cable work?
    "All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
    January 21, 2013 The End of an ERROR
    "Watches You Sleep" Shark taggart6's Avatar
    Oct 2003
    Quote Originally Posted by Thermo View Post
    Any HDMI cable should work if you plan to have audio and video connect to a single source/TV.
    If you want run video to the TV and the audio to a receiver, then you need a special cable that breaks it up.
    Has got that jut monroeski's Avatar
    Nov 2002
    I just got a random cheap one from Monoprice and it's worked fine for 4 years or so.
    Comp - i7 950, Radeon HD 5870, 6gb DDR3 1600
    Currently Playing - Borderlands 2
    Currently Reading - A Monster Calls by Patrick Ness
    SE PA
    OK thanks.
