Results 1 to 10 of 10
    Mar 2005
    NY
    Laptop upgrading parts
    So I have a DELL XPS L501X with the generic specs as:
    Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz Arrandale, 4GB of RAM Windows 7 Home Premium 64 bit.
    Manufacturer Dell Inc.
    Product Name XPS L501X
    Version A07
    Serial Number GM1N7P1
    PC System Type Mobile
    Machine Type AT/AT COMPATIBLE
    NVIDIA GeForce GT 420M
    Battery
    Sensor Value Min Max
    Voltages
    Current Voltage 12.85 V 12.85 V 12.85 V
    Capacities
    Designed Capacity 8400 mWh 8400 mWh 8400 mWh
    Full Charge Capacity 8202 mWh 8202 mWh 8202 mWh
    Current Capacity 8202 mWh 8202 mWh 8202 mWh
    BIOS Top <#TOC>
    Property Value
    BIOS Vendor Dell Inc.
    BIOS Version A07
    BIOS Date 03/29/2011
    BIOS Size 2048 KB
    BIOS Starting Segment E10Ah
    DMI Version 2.6
    CPU Info
    Number of Logical Processors 4
    Number of Physical Processors 1
    CPU #1 Intel Core i5 Top <#TOC>
    Property Value
    CPU Name Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz
    CPU Code Name Arrandale
    Vendor GenuineIntel
    Number of Bits 64
    Instruction Set MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, ET64, XD,
    VMX, EST
    Platform Name Socket 1156 LGA
    Revision K0
    Technology 32 nm
    Original Clock 2666 MHz
    Original System Clock 133 MHz
    Original Multiplier 20.1
    CPU Clock 2666 MHz
    System Clock 133.0 MHz
    QPI Link 2394.4 MHz
    Number of Cores 2
    Core #1
    Speed 1330.2 MHz
    Multiplier 10.0
    Core #2
    Speed 1330.2 MHz
    Multiplier 10.0
    Virtual Technology Supported Yes
    Hyper Threading Supported Yes
    Hyper Threading Enabled Yes
    Cache
    L1 Data Cache 2 x 32 KBytes
    L1 Instructions Cache 2 x 32 KBytes
    L2 Cache 2 x 256 KBytes
    L3 Cache 3072 KBytes
    Memory Summary Top <#TOC>
    Property Value
    Maximum Capacity 8192 MBytes
    Memory Slots 2
    Error Correction None
    DRAM Frequency 532.1 MHz
    Memory Timings 7-7-7-20 (CL-RCD-RP-RAS)
    Manufacturer Nanya Technology
    Part Number NT2GC64B88B0NS-CG
    Serial Number 428E2613
    Capacity 2048 MBytes
    Memory Type DDR3 (PC3-10700)
    Speed 667 MHz (DDR3 1333)
    Supported Frequencies 381.0 MHz, 457.1 MHz, 533.3 MHz, 609.5 MHz, 685.7
    MHz
    Memory Timings 5-5-5-14-19 at 381.0 MHz, at 1.5 volts (CL-RCD-RP-RAS-RC)
    Memory Timings 6-6-6-17-23 at 457.1 MHz, at 1.5 volts (CL-RCD-RP-RAS-RC)
    Memory Timings 7-7-7-20-27 at 533.3 MHz, at 1.5 volts (CL-RCD-RP-RAS-RC)
    Memory Timings 8-8-8-22-30 at 609.5 MHz, at 1.5 volts (CL-RCD-RP-RAS-RC)
    Memory Timings 9-9-9-25-34 at 685.7 MHz, at 1.5 volts (CL-RCD-RP-RAS-RC)
    Manufacturing Date 2011, Week 4
    EPP SPD Support No
    XMP SPD Support No
    Serial Number 7A742614
    MHz
    EPP SPD Support No
    XMP SPD Support No
    Batteries Top <#TOC>
    Property Value
    Microsoft ACPI-Compliant Control Method Battery
    Device ID ACPI\PNP0C0A\0
    Status 0x0180200a Started
    Problem 0x00000000 (0)
    Service CmBatt
    Capabilities 0x00000030
    Config Flags 0x00000000
    Class Battery
    Manufacturer Microsoft
    Hardware IDs ACPI\PNP0C0A
    Class GUID {72631e54-78a4-11d0-bcf7-00aa00b7b32a}
    Enumerator name ACPI
    Description Microsoft ACPI-Compliant Control Method Battery
    DriverVersion 6.1.7600.16385
    MatchingDeviceId composite_battery
    DriverDesc Microsoft Composite Battery
    Class Battery
    ClassDesc Batteries
    IconPath %systemroot%\system32\batt.dll,-2
    Installer32 batt.dll,BatteryClassInstall
    NoInstallClass 1
    I'd like to upgrade the RAM, HDD). Is there any difference between this list of RAM. I'm not sure if either of these will make a diff:
    Kingston 8GB (2x4GB)
    GSKILL 8GB (2x4GB)
    Patriot 8GB (2x4GB)
    They are all the same price
    With the additional RAM, will my power be enough? Lastly, I want to keep my laptop from overheating, any advice on how to tweak the fan?
    MOBO: Biostar TZ68K+ Intel Z68 ATX
    CPU: Intel Core i7-2700K
    RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB)
    CPU COOLING:Corsair Hydro Series H80
    VIDEO: MSI TWIN FROZR II GeForce GTX 570
    HDD: Intel 320-160GB SSD
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    MEDIA: Plextor Dual DVD
    PSU: CORSAIR HX750 750W
    CASE: Antec Twelve Hundred V3 ATX Full Tower
    OS: WIN 7 x64 Home Premium
    Monitor: Westinghouse 32" LCD 1080p
    Apr 2010
    All of those RAM kits will be basically identical in terms of speed. If you have any preference between those brands with regards to service/warranty I'd go for that one, other than that it doesn't matter.
    Quote Originally Posted by kujoe2002 View Post
    Powerful enough for what? It'll have more RAM than before so if you were running out of RAM with the current configuration then you should be good after the upgrade.
    The only other real upgrade you can do is to put in an SSD. That will increase the perceived performance by a lot, but of course the price per GB way more than a normal hard drive - but if you only need 128GB then it's a no-brainer, even for 256GB I'd default to SSD by now with prices being less than $1/GB.
    Mar 2005
    NY
    Quote Originally Posted by Steven P Jobs View Post
    Sorry, I didn't say it right. What I meant was will the power supply be powerful enough. I'm thinking of it like the desktops and whether the powersupply will be powerful enough to juice all the parts. That's the same thing I'm asking here.
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    Apr 2010
    There's not going to be a noticeable difference in power draw between 4GB and 8GB RAM. Likewise hard drives pretty much all have identical power draw regardless of capacity and RPM. SSDs use quite a bit less power than a spinning HDD. If you want to get really technical there is some difference, but not an amount that matters in real world use.
    Mar 2005
    NY
    now what about the heat? will having 8GB of ram fry my dell? I remember old stories about dell laptops catching fire..
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    That was due to batteries failing during charging, or shorting out.
    Apr 2010
    If the Laptop's specs say it can handle 8GB RAM, then it can. Don't be misled by the "Gamer RAM" with heatsinks on it, RAM produces basically no heat.
    Hammerhead Shark bugspop1's Avatar
    USA
    Last week I ordered the G.Skill RAM you have listed as a possibility. They had a Promo Code in an E-Mail I received for $5.00 off, so I picked it up for $34.99 shipped. The upgrade was for my Acer Aspire and went flawlessly. I also ordered a this hard drive that had a $20 Promo code making the hard drive $69.99 shipped: http://www.newegg.com/Product/Produc...82E16822148591. Again, this upgrade too went flawlessly. I used Acronis True Image Home ver. 11.0 and created a Cloned Drive to replace the original Toshibia 320gb 5400rpm hard drive. Both of these upgrades made a huge difference in boot time and opening programs.
    Good luck with your upgrade!
    CoolerMaster Cosoms Full Tower
    Enermax Revolution 1050w PSU (Modular Cabling)
    AMD PhenomII X4 940@3.0ghz Black Edition
    Asus M4A79 Deluxe
    4x2GB G.Skill DDR2 1066 PC2 8500
    2x1TB Seagate Hard Drives
    2xLite-On DVD-RW Smarterase/Lightscribe
    XFX nVidia GeForce 285 GTX 1GB
    26" Westinghouse Monitor
    Logitech Webcam 9000 Pro
    Logitech MX 5500 Combo
    Logitech z-640 5.1 Surround Sound
    Windows Vista Ultimate 64bit
    Brother MFC-9440cn AIO
    Brother MFC-845cw AIO
    Brother QL-570 Label Printer
    Mar 2005
    NY
    Quote Originally Posted by bugspop1 View Post
    I already have a seagate 7200rpm 500GB HDD. This was a custom build and I requested the 7200 as I don't trust anything lower than that for a single drive system. I am upgrading the RAM as I think I already have the best CPU.
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    USA
    Yes, the extra RAM can definitely help your laptop out! I was really impressed with the results I got from my upgrade 3gb to 8gb! I've been using G.Skill for quite some time and have had great results (no dead sticks). Started using G. Skill back with my AMD Athlon XP 3000+, just standard DDR. I've used it in all of my desktops since, and Laptops too!
    As for the Seagate Hard Drive: Yes the drive I purchased is 7200 RPM, but if you look at it more closely it is a Hybrid Drive. It has 32mb Cache and NCQ Solid State. It's kind of a cross inbetween the old style hard drives and the Newer SSD Drives. Many 7200RPM drives only have 16mb Cache or less. There are quite a few 7200RPM hard drives that have 32-64mb cache but you pay top $$$$ for them. Knowing Dell and their upgrades, they put the cheapest drive they could get for the money (as long as it was 7200RPM)! There is nothing wrong with a Seagate 7200RPM Drive, 7200RPM is 7200RPM and is always a better faster drive than the typical 5400-5900RPM drives many manufacturers put in their laptops! I too always upgrade my Laptop Hard Drives from a 5400RPM to a 7200RPM Hard Drive. I always keep the extra hard drives for backing up and and Extra Hard Space. I have an external hookup for the drives.
    Asus M4A79 Deluxe
