Results 1 to 8 of 8
    Jun 2005
    Two BSODs in two days...is my mobo going down?
    Hi guys,
    I've had two BSOD errors (and multiple crashes with each), at random over the past two days.
    The first BSOD said "APC INDEX MISMATCH" and the second said, "MEMORY MANAGEMENT PROBLEM".
    This is very concerning to me because the last time I started getting frequent BSOD crashes with various errors was on my previous PC where the motherboard eventually went kaput.
    I've ran scandisk, disk cleanup, and system file checker so far....
    If anyone has any ideas, that would be helpful.
    AMD Phenom 2 X4 : 955 BE
    Gigabyte GA-MA790XT-UD4P
    4GB DDR3 Corsair 1333
    XFX Radeon 4890 1GB
    320GB Western Digital RE3
    1 TB Western Digital Black
    750W Corsair PSU
    Thermaltake Armor+ MX Case
    NEC DVD-RW 3520
    Razer Copperhead Mouse
    Windows 7 Pro
    The Professional Mod vertices's Avatar
    Palm Coast, FL
    Run memtest86 for at least a couple of hours. First thing I always do if I have suddenly occurring BSODs is to check all of my HDDs with a test from the manufacturer and several hours of memtest86.
    Mar 2005
    NY
    Quote Originally Posted by vertices View Post
    I agree.. I'd check the hard drives.. If you can, I'd slave the primary from another computer, make a copy of all the data then check the entire disk. I'd also do a check on the drivers and bios
    MOBO: Biostar TZ68K+ Intel Z68 ATX
    CPU: Intel Core i7-2700K
    RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB)
    CPU COOLING:Corsair Hydro Series H80
    VIDEO: MSI TWIN FROZR II GeForce GTX 570
    HDD: Intel 320-160GB SSD
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    MEDIA: Plextor Dual DVD
    PSU: CORSAIR HX750 750W
    CASE: Antec Twelve Hundred V3 ATX Full Tower
    OS: WIN 7 x64 Home Premium
    Monitor: Westinghouse 32" LCD 1080p
    Palm Coast, FL
    Every time we have a system come in with BSODs it is almost always RAM/HDD or a failing PSU. Often the OS is then hosed from BSODing so much. Rarely is it something else such as a Mobo or CPU or something.
    Jun 2005
    Update: Last night I pulled out all my ram, let it sit for a while, put it back in and haven't had a crash since. Could reseating the ram had any effect?
    Both hard drives passed all disk checks...
    Haven't ran memtest yet... (I need to leave it overnight but it will trouble me when sleeping cause of the bright lights in the case and the whirr of the fans)
    What do you check for drivers and bios?
    XFX Radeon 4890 1GB
    750W Corsair PSU
    NEC DVD-RW 3520
    Windows 7 Pro
    Jun 2005
    double post sry
    XFX Radeon 4890 1GB
    750W Corsair PSU
    NEC DVD-RW 3520
    Windows 7 Pro
    Mar 2005
    NY
    I use system mechanic and driver detective for those things. RAM has always been on the top of my checklist when hardware goes bad.
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    Palm Coast, FL
    You need to run memtest86 overnight. I would.
