Results 1 to 9 of 9
    Great White Shark rimmerchant's Avatar
    Apr 2003
    damn hit by virus. WSOCK32.DLL damanged? & Zonealarm preventing net acces how to fix.
    ok i got hit by some drive by virus from accidently clicking on some site
    long story short my Avast AV caught it before it did any lastin damange. I cleared the files but see some residual effects
    as far as I know. I ran Malwarebytes antimalware and avast and my C: is clean.
    but i still have a few residual effects.
    1) when I start Win7 my desktop icons are big and is like that everythime I restart
    2) When I have Zonealarm loaded I can't get interenet access
    3) I tried uninstalling and installing I get the no internet access again. (using full installer)
    4) if I try the "online installer" downloaded from the zonealarm website I keep getting a WSOCK32.DLL error.
    anyone know whats going on? I can't seem to google my issues.
    C2D Q6600 @ 3.2 ghz, Enermax Liberty 620watt PSU, Gigabyte GA-965PDS3 mobo, 4x2gb OCZ DDR2 800mhz, 2x OCZ vertex 60gb Raid0 + 1TB + 320gb HD, SB Xi-Fi Extreme Gamer, 16x DVDRW Liteon, Logitech Cordless MX3100 desktop w MX1000 mouse + G9 laser mouse, Logitech cordless rumblepad 2, Sennheiser HDR100 wireless headset, ATI Remote Wonder II, Logitech QuickCamPro 9000, Eyefinity Triple 24" Widescrn LCD + ATI 5870, Win 7 ultimate
    Mar 2005
    NY
    just saw this.
    I didn't realize Zonealarm came out with 64bit firewall. I'm assuming you only have the firewall and not their A/V stuff right? This is what I would do:
    Run housecall from trendmicro.com and complete a full scan.
    Download CC cleaner.
    Uninstall zonealarm and delete the registry info. When I was able to use zonealarm, it was the best firewall out there. I remember when I did a reformat, I had to reinstall a few times to get the settings right. Make sure all your other firewalls are turned off. You may have Zonealarm, Avast and Windows firewalls running. Having two firewalls, let alone 3 has always stopped all internet access for me.
    After you uninstalled zonealarm, run cc cleaner and clear the registry as well.
    MOBO: Biostar TZ68K+ Intel Z68 ATX
    CPU: Intel Core i7-2700K
    RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB)
    CPU COOLING:Corsair Hydro Series H80
    VIDEO: MSI TWIN FROZR II GeForce GTX 570
    HDD: Intel 320-160GB SSD
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    MEDIA: Plextor Dual DVD
    PSU: CORSAIR HX750 750W
    CASE: Antec Twelve Hundred V3 ATX Full Tower
    OS: WIN 7 x64 Home Premium
    Monitor: Westinghouse 32" LCD 1080p
    Mar 2005
    NY
    Wow so I downloaded Zonealarm. They now have free antivirus+ firewall. They are my favorite. I'm glad I checked this thread because I stopped using ZA after they no longer supported the free version for win 7 64bit - many years ago.. Now they do. I removed Microsoft Security Essentials, Outpost Firewall and disabled all windows security firewalls. Just installed this sucker. If you are having trouble getting through the ZA firewall, after you install it, you have to go to the "firewall" tab (which is the middle tab) and click on "view programs on the bottom." It gives you a look at every program that is trying to access the firewall. The first thing to remember about this firewall is that it MUST allow FULL ACCESS to "Host Process for Windows Services" in order to get ANY internet access through the firewall. Then it's just a matter of determining which programs you want to allow access to the web. Putting "checks" allow the processes to access the web. It's rather self-explanatory.
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    Mako Shark wh666-666's Avatar
    Jul 2006
    In a red kennel
    Quote Originally Posted by rimmerchant View Post
    Look at the avast log, google the manual removal instructions for the virus, or post and let us know, someone may have been hit by it, removed properly and then looking at places to post the removal guide. Which family and strain is it?
    wsock32.dll should be on your windows installation disk, if not you can download it here. You will need to boot from a linux disk, remove any wsock32 you find and replace with the clean one you have, then lock it as read only to stop the virus deleting/overwriting it. I would have a hunch here that you haven't gotten rid of the virus at all and it may be a worm.
    Jul 2006
    In a red kennel
    Oh so that post covered points 2,3,4 by the way, but on point 1: Try searching for all hidden desktop.ini files and delete every last one. Now when you set your icon size, it should stay that way.
    Mar 2005
    NY
    Quote Originally Posted by wh666-666 View Post
    other option is to just repair windows then set the desktop icons as "small icons"
    HDD: 250GB WD SATA
    HDD: 1TB WD SATA
    HDD: 500WD SATA
    Aug 2004
    Urbana, IL
    I'd backup and wipe the entire drive. I don't mess around with viruses. This is why I keep my important files on a back upped nas. I only have a c drive and a steam drive on my pc.
    Main Rig: Watercooled
    EVGA 680GTX | Intel 320 SSD + Crucial M4 256GB | Corsair 750TX | Corsair 800D
    Hackintosh Workstation: Aircooled
    EVGA 640 GT | WD RE4 500GB | PCP&C 600W | G5 Case
    Toys:
    iPhone 4 | iPad 3 | PS3 | Xbox 360 | PSP-3000 | Supermicro based NAS | Steelcase LEAP!
    Currently playing: Guild Wars 2
    Last Game Beaten: Walking Dead EP1
    Jul 2006
    In a red kennel
    Quote Originally Posted by Timman_24 View Post
    Less hassle free route.
    Quote Originally Posted by kujoe2002 View Post
    Repairing windows won't help if a virus is creating or deleting files like winsock32.dll. I gather rimmer has already tried to set the icon size to no avail. A repair does not clear out desktop.ini files which is needed.
    Aug 2004
    Urbana, IL
    Reinstalling windows is usually the fastest for me. By the time I've scoured the net researching for hours and trying numerous fixes, i could have reinstalled in an hour tops. Dump your important files on a USB and reinstall. Partition your hdds correctly next time if you haven't to make a reinstall less painful.
    Toys:
    Aug 2004
    Urbana, IL
    Toys:
